Like many try LUA and the arduino IDE or viceversa, now its my turn with the arduino IDE The examples of the libs worked fine, but I can not see how to connect between 2 esp and get a respond to the client from the server once the server got a msg from the client. I am very middle skill programmer so I copy & paste a lot and edit litle
the server code goes like:
WiFiClient client = server.available(); // Check if a client has connected
if (client==0) {
return;
Serial.println("");
Serial.println("New client");
// Wait for data from client to become available
while (client.connected() && !client.available()) {
delay(1);
// Read the first line of HTTP request
Serial.print(req); // I recieved msg ok!
//server.print("loco");
// client.print("loco");
delay(100);
and this is the basis of the client which seems to be fine:
delay(5000);
Serial.println(host);
WiFiClient client;
const int httpPort = 80;
return;
client.print("que onda");
delay(10);
while(client.available()){
Serial.print(line);
Hope someone can give me a hand on this to keep on going, thanks for reading!
Luciano
