By roy
#85346 Hi all i am new to esp8266 and need help i am trying to send data from a DS18B20 and send it to .php to write temp.html file and i can't figure what m i doing wrong
my scatch is
// Libraries
#include <OneWire.h>
#include <DallasTemperature.h>
#include <ESP8266WiFiMulti.h>
#include <ESP8266HTTPClient.h>
// Pin
#define ONE_WIRE_BUS 5 // DS18B20 pin
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature DS18B20(&oneWire);
#define USE_SERIAL Serial
ESP8266WiFiMulti WiFiMulti;
Serial.begin(115200); // Start Serial
USE_SERIAL.begin(115200);
// USE_SERIAL.setDebugOutput(true);
USE_SERIAL.println();
for(uint8_t t = 4; t > 0; t--) {
USE_SERIAL.printf("[SETUP] WAIT %d...\n", t);
USE_SERIAL.flush();
delay(1000);
WiFiMulti.addAP("*****", "*******");
void loop()
DS18B20.requestTemperatures();
String temp;
temp = String(DS18B20.getTempCByIndex(0));
Serial.println(temp);
HTTPClient http;
USE_SERIAL.print("[HTTP] begin...\n");
// configure traged server and url
http.begin("http://mywebserver/TEMP.php" ); //HTTP
int httpCode = http.POST(+"temp");
USE_SERIAL.print("[HTTP] POST...\n");
// start connection and send HTTP header
// httpCode will be negative on error
if(httpCode > 0) {
// HTTP header has been send and Server response header has been handled
USE_SERIAL.printf("[HTTP] POST... code: %d\n", httpCode);
// file found at server
if(httpCode == HTTP_CODE_OK) {
String payload = http.getString();
USE_SERIAL.println(payload);
} else {
USE_SERIAL.printf("[HTTP] POST... failed, error: %s\n", http.errorToString(httpCode).c_str());
http.end();
delay(1000);
my .php file
<?php
$temp = $_GET['temp'];
$temp = $_POST["temp"];
$file = 'temp.html';
THX ROY
