By domonetic
#34997 which is the size of memory esp-07?
buy a module, when tested by command throws me these results.
Code: Select allAT+GMR
AT version:0.30.0.0(Jul  3 2015 19:35:49)
SDK version:1.2.0
Ai-Thinker Technology Co.,Ltd.
Build:1.2.0.A Aug  7 2015 17:21:44
 ets Jan  8 2013,rst cause:2, boot mode:(3,7)
load 0x40100000, len 1396, room 16
tail 4
chksum 0x89
load 0x3ffe8000, len 776, room 4
tail 4
chksum 0xe8
load 0x3ffe8308, len 540, room 4
tail 8
chksum 0xc0
csum 0xc0
2nd boot version : 1.4(b1)
  SPI Speed      : 40MHz
  SPI Mode       : QIO
  SPI Flash Size & Map: 8Mbit(512KB+512KB)
jump to run user2 @ 81000
ÂÕMEM CHECK FAIL!!!
ärlrú
but in arduino, I not have option 8Mb.
I have only 4M (1M spiffs) or 4M (3M spiffs)
I do not understand what the right to program
