By JoeO
#41183
zxa wrote:
JoeO wrote:Have you tried a separate 3.3 volt supply?
No, I haven't there is 3.3v going to the ESP though. When I've measured it on a multimeter so theres no problem there. I think somethings internally wrong so might need to reflash it.
Why would anyone help you when you refuse to try the one fix that has helped so many others?
By zxa
#41207
I'll try with a separate 3.3v. But I emailed the company sent them my diagram and said it should be fine if I put in a logic level convertor. So I'll try both things and see how that goes.
