By Barnabybear
#32595
for Serial.print(result), between 1275 and 540 was printed to the serial monitor. It was usually around 600.
The number range might have been more vast if I tested it outside over longer distances.
But serial monitor did not work at all until delay(result); was commented out.
For serial.print(out), a RSSI range was printed between negative 30 something, and negative 90 something, I don't remember
Hi thats good, its what I have been getting.
Whilst connected all has been working well at this end - have been walking round with a battery pack & even very small differences in the flash rate are noticeable. The problem is the delay between connecting and geting a reliable value from WiFi.RSSI(). It appears that for the first 1500ms after WL_CONNECTED reports true, WiFi.RSSI() reports the value 31, then the correct value. Anyway bed time now in the UK, will look again tomorrow.
