I will test out the rest of the circuit later to see if the whole project works as it should.
Explore... Chat... Share...
/* This code was written on 10/4/2015.
/* Create a WiFi access point */
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
extern "C" {
#include "user_interface.h"
#define WIFI_MODE_AP
/* Set these to your desired credentials. */
const char *ssid = "Proximity Trigger 1";
const char *password = "thereisnospoon";
//Reference as station counter as "devices"
unsigned char devices;
ESP8266WebServer server(80);
void handleRoot() {
delay(1000);
Serial.print("Configuring access point...");
/* You can remove the password parameter if you want the AP to be open. */
WiFi.softAP(ssid, password);
Serial.print("AP IP address: ");
Serial.println(myIP);
server.on("/", handleRoot);
server.begin();
pinMode(2, OUTPUT);
digitalWrite(2, LOW);
devices = wifi_softap_get_station_num();
if (devices >= 1) {
digitalWrite(2, HIGH);
delay(2000);
digitalWrite(2,LOW);
else if (devices <=1) {
delay(2000);
server.handleClient();
unsigned int prevMillis = 0;
boolean ledState = false;
if ((millis() - prevMillis) > 1000) { // 1000 millis = 1 second
prevMillis = millis();
if (devices >= 1) {
if (!ledState)
ledState = !ledState;
else {
ledState = false;
