By Mmiscool
#30309 I get the following error msg.
Code: Select allESP8266Basic:1436: error: 'class IPAddress' has no member named 'toString'
By Mmiscool
#30477 The latest staging version will cause my program to crash when compiled. it crashed immediately when it start up.
How can I copy the files required from the latest staging release in to my current set up?
I am not to familiar with the arduino set up but i have the following folders on my hard drive.
AppData\Roaming\Arduino15\packages\esp8266\hardware\esp8266\1.6.5-1044-g170995a\cores\esp8266
The 2 files
IPAddress.h
IPAddress.cpp
seem to reside there.
Can you point me at exact links to get the new files?
and are there any other files that will need to be replaced?
