Is there a clear example somewhere of how to update an arduino sketch that's running on an esp8266 by sending the updated sketch over-the-air?
Is it even currently possible?
The "reference" document at https://github.com/esp8266/Arduino/blob ... ference.md does seem to obliquely refer to it thusly:
Sketch OTA update File system EEPROM WiFi config (SDK)
@WhiteHare This isn't documented anywhere, but you may find something useful in this issue: esp8266/Arduino#268 (https://github.com/esp8266/Arduino/issues/268)
basically the flow is like this:
flash DNS_SD_Arduino_OTA example sketch
after some time, the board will appear in 'ports' menu
Select 'OTA' instead of 'Serial' in Tools > Upload using
You can now do some sketches and flash the sketch. It should be uploaded over-the-air
You also need python installed and in PATH, because the script which does OTA is currently written in python.
There are also samples bundled with the IDE which show how to do OTA using an HTTP upload. In some contexts this might be more convenient.
ESP8266 Arduino add-on
Arduino IDE 1.6.5
