Thanks for reporting.
Which example do you try to compile?
It is a strange error.
line 190 in ESP8266SocketBase.cpp shows me:
sint8 ESP8266SocketBase::send(const char* data)
Explore... Chat... Share...
inx wrote:Hi
line 190 in ESP8266SocketBase.cpp shows me:Code: Select allsint8 ESP8266SocketBase::send(const char* data)
/// Do not remove the include below
#include "ClientTEST.h"
#include <ESP8266Client.h>
const char* ssid = "HogeveenNet";
const char* password = "??????????";
// create a TCP client
ESP8266Client client("192.168.2.185", 222);
unsigned long now = 0;
// general callbacks
void onDataCb(ESP8266Client& client, char *data, unsigned short length)
Serial.write(data, length);
// TCP callbacks
void onConnectCb(ESP8266Client& client)
Serial.println("connected to server");
void onDisconnectCb()
Serial.println("disconnected from server");
void onReconnectCb(ESP8266Client& client, sint8 err)
Serial.print("reconnect CB: ");
Serial.println(espErrorToStr(err));
Serial.println(espErrorDesc(err));
delay(10);
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
// set callback functions
client.onData(onDataCb);
client.onConnected(onConnectCb);
client.onDisconnected(onDisconnectCb);
client.onReconnect(onReconnectCb);
if (client.isConnected()) {
Serial.println("sending to server");
client.send("ping\r\n");
delay(1000);
} else {
// connect
boolean res = client.connect();
if (!res) {
// Serial.println("could not connect");
delay(10);
