derek bernsen wrote:Ok. I think I've fixed it. No error messages with the code anymore. I'll upload the code to my ESP-01 or maybe my ESP-201 module for initial testing later.
Instead of messing with varying the PWM period based on RSSI, why not go with a simple method of 1 beep per second far away 4 beeps very near etc, this way you could use simple logic based on RSSI to determine amount of beeps required.
A simple solution.
Hope this helps
Dans
PS: Take a look at my wifi scan and acquire routine sometime ago, this also incorporates an OLED, would be cool to have visual display on this.
Dans
This has been tested, but only blinks every 4 seconds or so, or is full on, so not a range of blink rates. No idea why:
#include <Arduino.h>
int buzzerPin = 2;
int buzzerState = LOW;
const char* SSID = "belkin.d4c";
// Return RSSI or 0 if target SSID not found
int32_t getRSSI(const char* target_ssid) {
byte available_networks = WiFi.scanNetworks();
for (int network = 0; network < available_networks; network++) {
if (strcmp(WiFi.SSID(network), target_ssid) == 0) {
return WiFi.RSSI(network);
return 0;
pinMode(buzzerPin, OUTPUT);
unsigned long before = millis();
int32_t rssi = getRSSI(SSID);
int result = (rssi + 33) * -15;
// int result = rssi * -7.7;
unsigned long after = millis();
digitalWrite(buzzerPin, HIGH);
delay(result);
digitalWrite(buzzerPin, LOW);
//(rssi * -7.7)
Here's the second program I tried, it works as a non-blinking meter, it emits a constant tone that increases in volume when I go closer to the beacon:
int buzzerPin = 2;
return 0;
int volume = (rssi + 33) * -15;
analogWrite(2, volume);
I am using a nearby WiFi router as the AP to test, I'll use the beacon later on.
I was incorrect. Neither program is working at all.
Please help me figure out the code I'm having trouble with. I want to know why neither program is working.
No rush, just if anyone has time to spare.
- Donovan
