Using the following code, when I try to set a GPIO to be input to read the DHT, it resets / reboots the ESP module (I'm using Serial Monitor to watch it) and I also get a hex dump...
void getDhtSensorData() {
Serial.println("\ngetDhtSensorData() entered...");
pinMode(DHT_DATA_PIN, INPUT);
Other code removed for clarity - the above line causes the reboot
Serial.println("Exiting getDhtSensorData()...");
void getSensorData() {
Serial.println("getSensorData() entered...");
getDhtSensorData();
// getBmpSensorData();
Serial.println("Exiting getSensorData()...");
delay(5000);
Serial.println("\n\nStarting loop()...");
Serial.println("Calling getSensorData()...");
getSensorData();
The first time I upload / run the code I get the following and the code loop just stops...
0x0f
csum 0x0f
~ld
Starting loop()...
ets Jan 8 2013,rst cause:4, boot mode:(1,6)
wdt reset
If I then press the reset button on the GizWits daughter board it goes into a proper repeating loop but each time I get the same as above as well as a hex dump.
If I remove the line...
pinMode(DHT_DATA_PIN, INPUT);I've even disconnected the DHT circuitry completely but just using pinMode seems to be causing problems and I don't understand why.
Cheers,
Brian
