- Wed May 25, 2016 5:12 pm
#48019
Hi, davino, martin,
Thanks for your replies
I worked on a version using streams and I think I got it almost right, but the result is not perfect yet.
I'm attaching the code below, and to make it simpler, I just tried to proxy the New-York Times homepage (just the html, not the images).
Here is a screencast of how it behaves:
http://screencast.com/t/2IKIEhoJVBijI'm first loading the page directly in Chrome so we have the reference. Then I'm loading the page through the ESP. As you can see, most of the times, I'm getting a blank page of only about 5KB (and I cannot even view its source, which is weird), and only once I could get the full page loaded.
Also, the processing looks extremely slow to me (no matter if it works or not). It looks like we have download bursts interleaved with long pauses.
Here is the code I'm using. Sorry, it's a bit long with all the comments, but it should be easy to use to reproduce:
const char* ssid = "********";
const char* password = "****************";
WiFiServer localServer(80);
const char* remoteHost = "www.nytimes.com";
char buffer[1024];
delay(10);
// Connect to WiFi network
WiFi.begin(ssid, password);
Serial.print(".");
// Start the server
localServer.begin();
// Print the IP address
Serial.print("Started. Connect to: http://");
Serial.print(WiFi.localIP());
// Check if a client browser has connected
WiFiClient browserClient = localServer.available();
if (!browserClient) {
return;
// Wait until the client browser sends some data
Serial.println("Serving request");
while(!browserClient.available()){
delay(1);
// Read the first line of the request (and ignore it)
String request = browserClient.readStringUntil('\r');
Serial.println("Request is " + request);
browserClient.flush();
// Connect to the real server
WiFiClient client;
Serial.println("Connecting to remote server");
if (!client.connect(remoteHost, 80)) {
// Error connecting to real server
Serial.println("Error contacting remote server");
return;
Serial.println("connected");
// Make a HTTP request:
client.println(String("GET / HTTP/1.1\r\n") +
"Host: " + remoteHost + "\r\n" +
"Connection: close\r\n\r\n");
Serial.println("Request sent");
// Wait for response
while(!client.available()){
delay(1);
Serial.println("Client available");
// And forward it to the browser
while (client.available()) {
int bytesRead = client.readBytes(buffer, sizeof(buffer));
Serial.print(bytesRead);
Serial.println(" bytes read");
browserClient.write((const char*)buffer, bytesRead);
Serial.println("Response sent");
delay(1);
Serial.println("BrowserClient served");
Do you see a reason why it behaves that way ?
Best regards,
Vicne
