I recently started using the SPIFFS File System like the FSBrowser.ino example, and while it's been great in terms of separating code, as my code continues to grow it has not been great in terms of stability.
Ever since I began adding more and more javascript, I began to have errors pop up for various files, whether it's my HTML/CSS/JS, and the primary error I see is ERR_CONTENT_LENGTH_MISMATCH.
//File Read for File System
bool handleFileRead(String path)
if(mySerial)
mySerial.println("handleFileRead: " + path);
if(path.endsWith("/")) path += "index.htm";
String contentType = getContentType(path);
String pathWithGz = path + ".gz";
if(SPIFFS.exists(pathWithGz) || SPIFFS.exists(path))
if(SPIFFS.exists(pathWithGz))
path += ".gz";
File file = SPIFFS.open(path, "r");
if(mySerial)
mySerial.println("TEST: " + path + " FILE OPEN: " + file.size());
size_t sent = server.streamFile(file, contentType);
if(mySerial)
mySerial.println("TEST: " + path + " SIZE: " + file.size());
file.close();
if(mySerial)
mySerial.println("TEST: " + path + " FILE CLOSE");
return true;
} //end if
return false;
} //end function handleFileReadSo after that happened I began examining the handleFileRead() function that I copied from the FSBrowser.h example and after testing various print statements it seems the hangup occurs within this line:
template<typename T> size_t streamFile(T &file, const String& contentType){
setContentLength(file.size());
if (String(file.name()).endsWith(".gz") &&
contentType != "application/x-gzip" &&
contentType != "application/octet-stream"){
sendHeader("Content-Encoding", "gzip");
send(200, contentType, "");
return _currentClient.write(file, HTTP_DOWNLOAD_UNIT_SIZE);
}So from there, I went into ESP8266WebServer.h and found the streamFile() function. Once inside this function, I discovered this line:
From this I deduced two things:
- There is a download limitation capping at HTTP_DOWNLOAD_UNIT_SIZE (which is defined at 1460).
- This function calls another function within the WiFiClient class called write().
So I followed the trail to this function: size_t WiFiClient::write(const uint8_t *buf, size_t size).
SoftwareSerial mySerial(12,13);
mySerial.begin(115200);
if(mySerial)
mySerial.print("Size: ");
mySerial.println(size);
if (!_client || !size)
if(mySerial)
mySerial.println("FAILURE");
return 0;
if(mySerial)
mySerial.println("SUCCESS");
return _client->write(reinterpret_cast<const char*>(buf), size);
}Now this doesn't quite match because the first parameter of the write() function that was called is of type File, while the first parameter of this function is uint8_t, but I placed some print statements within here nonetheless and they execute as the files are being loaded so I believe I've found the correct function.
However, now I'm at a loss as to how to continue fixing the problem from here, since there is only a recursive call and the error seems to occur because the culprit file doesn't finish loading (at least according to chrome debugger's network tab)
As you can see, the style.css file is listed as being 3 kilobytes, which is of course wrong: my css file is 27 kilobytes.
So it appears that there's an issue loading files (this is not exclusive to the css file, it has happened with my javascript files as well and appears to be random). I have tried minifying all the files and it hasn't fixed the issue; so I could really use some help determining how to fix this.
Here's the source for the rest of my code:
Primary ino file
//Header File
#include "HHIO_Portal.h"
//Function used to verify incoming information from the teensy to the wifi card via the communication protocol
void recInfoWifi()
COMMUNICATION PROTOCOL
if(Serial.available() > 0)
//SOM
if(initialCounter == 0)
rx_byte = Serial.read();
//Print Start of Message
//if(mySerial)
//mySerial.print("0x");
if(rx_byte<0x10)
//if(mySerial)
//mySerial.print("0");
} //end if
//if(mySerial)
//mySerial.println(rx_byte, HEX);
//Finish the SOM reading sequence
initialCounter++;
} //end if
//Invalid Message
if((!messageBegun) && (rx_byte != som) && (invalidMessageFlag == 0))
invalidMessageFlag = 1;
//if(mySerial)
//mySerial.println("INVALID MESSAGE START");
} //end if
//If the SOM was read successfully...
if((!messageBegun) && (rx_byte == som) && (invalidMessageFlag == 0))
messageBegun = true;
//if(mySerial)
//mySerial.println("MESSAGE BEGUN TRUE");
} //end if (messageInProgress && rx_byte)
//Message Length
if((messageBegun) && (!messageInProgress) && (invalidMessageFlag == 0))
serialCurrent = Serial.available();
if(serialCurrent > 0)
receivedMessageLength = (uint8_t)Serial.read();
//if(mySerial)
//mySerial.print("MESSAGE LENGTH: ");
//mySerial.println(receivedMessageLength);
//} //end if
messageInProgress = true;
//if(mySerial)
//mySerial.println("MESSAGE IN PROGRESS TRUE");
} //end if (serialCurrent)
} //end if (messageBegun && messageInProgress)
//Subsystem, Message Content and EOM
if((messageInProgress) && (invalidMessageFlag == 0))
if(serialCurrent >= receivedMessageLength)
Serial.readBytes(rxBuff, receivedMessageLength);
if((byte)rxBuff[receivedMessageLength-1] != eom)
//if(mySerial)
//mySerial.println("ERROR");
//mySerial.write(Serial.read());
//} //end if
} //end if (rxBuff != eom)
SUBSYSTEM
receivedSubsys = rxBuff[0];
//Print Subsystem
//if(mySerial)
if(receivedSubsys<0x10)
//if(mySerial)
} //end if
//if(mySerial)
//mySerial.println(receivedSubsys, HEX);
MESSAGE CONTENT
//NUM REFRESH
if(receivedSubsys == SUBSYS_14)
currNumRefresh = rxBuff[1];
//END OF MESSAGE
//if(mySerial)
//mySerial.println(rxBuff[2], HEX);
//} //end if
initialCounter = 0;
messageBegun = false;
messageInProgress = false;
receivedMessageLength = 0;
} //end if (SUBSYS_14)
//MICROSWITCH C
else if(receivedSubsys == SUBSYS_4)
currMicroC = rxBuff[1];
//END OF MESSAGE
//if(mySerial)
//} //end if
initialCounter = 0;
} //end else if (SUBSYS_4)
else if(receivedSubsys == SUBSYS_5)
currMicroD = rxBuff[1];
//END OF MESSAGE
//if(mySerial)
//} //end if
initialCounter = 0;
} //end else if (SUBSYS_5)
else if(receivedSubsys == SUBSYS_6)
currMicroE = rxBuff[1];
//END OF MESSAGE
//if(mySerial)
//} //end if
initialCounter = 0;
} //end else if (SUBSYS_6)
else if(receivedSubsys == SUBSYS_7)
currPressureC = rxBuff[1];
//END OF MESSAGE
//if(mySerial)
//} //end if
initialCounter = 0;
} //end else if (SUBSYS_7)
else if(receivedSubsys == SUBSYS_8)
currPressureD = rxBuff[1];
//END OF MESSAGE
//if(mySerial)
//} //end if
initialCounter = 0;
} //end else if (SUBSYS_8)
else if(receivedSubsys == SUBSYS_9)
currPressureE = rxBuff[1];
//END OF MESSAGE
//if(mySerial)
//} //end if
initialCounter = 0;
} //end else if (SUBSYS_9)
else if(receivedSubsys == SUBSYS_10)
currValveStatusNumC = rxBuff[1];
//END OF MESSAGE
//if(mySerial)
//} //end if
initialCounter = 0;
} //end else if (SUBSYS_10)
else if(receivedSubsys == SUBSYS_11)
currValveStatusNumD = rxBuff[1];
//END OF MESSAGE
//if(mySerial)
//} //end if
initialCounter = 0;
} //end else if (SUBSYS_11)
else if(receivedSubsys == SUBSYS_12)
currValveStatusNumE = rxBuff[1];
//END OF MESSAGE
//if(mySerial)
//} //end if
initialCounter = 0;
} //end else if (SUBSYS_12)
else if(receivedSubsys == SUBSYS_13)
currFluid = rxBuff[1];
//END OF MESSAGE
//if(mySerial)
//} //end if
initialCounter = 0;
} //end else if (SUBSYS_13)
} //end else
} //end if (messageInProgress)
} //end if (Serial.available)
} //end comProtocolWifi
//Function used to send information to the teensy in order to control the HHIO PTT
void sendInfoWifi()
unsigned long currTime = millis();
//SEND
if(currTime - prevTimeTest > testInterval)
prevTimeTest = currTime;
//Test Message
messageLength = 3;
subsys = SUBSYS_DBG;
messageContent = wifiCounter;
//Teensy Console
Serial.write(som);
Serial.write(messageLength);
Serial.write(subsys);
Serial.write(messageContent);
Serial.write(eom);
wifiCounter++;
} //end if (RECEIVE INFO)
} //end function sendInfoWifi
void setup()
//Initiate Serial connection to Teensy
//This is for debugging/housekeeping (And all console messages that use mySerial as opposed to Serial)
FILE SYSTEM
SPIFFS.begin();
Dir dir = SPIFFS.openDir("/");
while (dir.next()) {
String fileName = dir.fileName();
size_t fileSize = dir.fileSize();
if(mySerial)
mySerial.printf("FS File: %s, size: %s\n", fileName.c_str(), formatBytes(fileSize).c_str());
} //end while
if(mySerial)
mySerial.printf("\n");
} //end SPIFFS BEGIN
WIFI INIT
if(mySerial)
mySerial.printf("Connecting to %s\n", ssid);
//Make the initial Wifi connection
if (String(WiFi.SSID()) != String(ssid)) {
WiFi.begin(ssid, password);
} //end if
//Wait for the Wifi to finish connecting
if(mySerial)
mySerial.print(".");
} //end while
//IP Address for webpage
if(mySerial)
mySerial.println("");
mySerial.print("Connected! IP address: ");
mySerial.println(WiFi.localIP());
} //end if
//Might not need this
MDNS.begin(host);
//Hostname for webpage
if(mySerial)
mySerial.print("Open http://");
mySerial.print(host);
mySerial.println(".local/edit to see the file browser");
} //end if
SERVER INIT
//list directory
server.on("/list", HTTP_GET, handleFileList);
//load editor
server.on("/edit", HTTP_GET, [](){
if(!handleFileRead("/edit.htm"))
server.send(404, "text/plain", "FileNotFound");
//create file
server.on("/edit", HTTP_PUT, handleFileCreate);
//delete file
server.on("/edit", HTTP_DELETE, handleFileDelete);
//first callback is called after the request has ended with all parsed arguments
//second callback handles file uploads at that location
server.on("/edit", HTTP_POST, [](){ server.send(200, "text/plain", ""); }, handleFileUpload);
//called when the url is not defined here
//use it to load content from SPIFFS
server.onNotFound([](){
if(!handleFileRead(server.uri()))
//get heap status, analog input value and all GPIO statuses in one json call
server.on("/all", HTTP_GET, [](){
String json = "{";
json += "\"heap\":"+String(ESP.getFreeHeap());
json += ", \"analog\":"+String(analogRead(A0));
json += ", \"gpio\":"+String((uint32_t)(((GPI | GPO) & 0xFFFF) | ((GP16I & 0x01) << 16)));
json += "}";
server.send(200, "text/json", json);
json = String();
//Start the server
server.begin();
if(mySerial)
mySerial.println("HTTP server started");
//Open the websocket connection in order to update the status values on the page without refreshing
webSocket.begin();
webSocket.onEvent(webSocketEvent);
} //end Setup
void loop()
//SEND INFO TO TEENSY
sendInfoWifi();
//RECEIVE INFO FROM TEENSY
recInfoWifi();
//CONTINUE WEBSOCKET CONNECTION
webSocket.loop();
//SERVE WEBPAGE TO THE USER
server.handleClient();
} //end loopPrimary ino header file
//Initiate necessary libraries
#include <SoftwareSerial.h>
#include <HHIO_Subsystems.h>
//#include <pfodESP8266WiFi.h>
#include <WebSocketsServer.h>
//#include <pfodESP8266WebServer.h>
#include <ESP8266WebServer.h>
#include <ESP8266mDNS.h>
#include <FS.h>
//Serial connection for debugging (RX, TX)
//SSID/Pass/Host
const char* ssid = "*****";
const char* password = "*****";
const char* host = "esp8266fs";
//Setup File System Connection
MDNSResponder mdns;
//Web Server
ESP8266WebServer server(80);
//File System
File fsUploadFile;
//Websocket
WebSocketsServer webSocket = WebSocketsServer(81);
//Invalid Message
uint8_t invalidMessageFlag = 0;
//Counter for testing serial connection
uint8_t wifiCounter = 0;
//Com. Protocol Buffer
uint8_t rxBuff[256];
//Start of Message
uint8_t som = 0x11;
//End of Message
uint8_t eom = 0x12;
//Subsystem variables
uint8_t subsys;
uint8_t receivedSubsys;
//Read Byte for Com. Protocol
uint8_t rx_byte = 0x00;
//Message length variables
uint8_t messageLength = 0;
uint8_t receivedMessageLength = 0;
//Message content variable
uint8_t messageContent;
//Variable to check incoming serial content
uint8_t serialCurrent;
//Counter used for verifying the som variable
int initialCounter = 0;
//Message progression variables
boolean messageBegun = false;
boolean messageInProgress = false;
//Variables currently used to read status info coming from the teensy (CURRENTLY RANDOMIZED INFO)
int currNumRefresh = 0;
int currMicroC = 0;
int currMicroD = 0;
int currMicroE = 0;
int currPressureC = 0;
int currPressureD = 0;
int currPressureE = 0;
int currValveStatusNumC = 0;
int currValveStatusNumD = 0;
int currValveStatusNumE = 0;
int currFluid = 0;
//Buffer for sending information from Arduino to the webpage
char statusbuf[256];
//Valve 1
String valveStatusC = "Closed";
String valveTubePropsC = "175px solid #00ADEF";
String valveColorC = "red";
//Valve 2
String valveStatusD = "Closed";
String valveTubePropsD = "175px solid #00ADEF";
String valveColorD = "red";
//Valve 3
String valveStatusE = "Closed";
String valveTubePropsE = "175px solid #00ADEF";
String valveColorE = "red";
//Variables for sending test message to teensy
long prevTimeTest = 0;
long testInterval = 5000;
//Format Bytes
String formatBytes(size_t bytes){
if(mySerial)
mySerial.println("formatBytes FUNC");
if (bytes < 1024){
return String(bytes)+"B";
} //end if
else if(bytes < (1024 * 1024)){
return String(bytes/1024.0)+"KB";
} //end else if
else if(bytes < (1024 * 1024 * 1024)){
return String(bytes/1024.0/1024.0)+"MB";
} //end else if
else {
return String(bytes/1024.0/1024.0/1024.0)+"GB";
} //end else
} //end function formatBytes
//Content Type for File System
String getContentType(String filename)
if(server.hasArg("download")) return "application/octet-stream";
else if(filename.endsWith(".htm")) return "text/html";
else if(filename.endsWith(".html")) return "text/html";
else if(filename.endsWith(".css")) return "text/css";
else if(filename.endsWith(".js")) return "application/javascript";
else if(filename.endsWith(".png")) return "image/png";
else if(filename.endsWith(".gif")) return "image/gif";
else if(filename.endsWith(".jpg")) return "image/jpeg";
else if(filename.endsWith(".ico")) return "image/x-icon";
else if(filename.endsWith(".xml")) return "text/xml";
else if(filename.endsWith(".pdf")) return "application/x-pdf";
else if(filename.endsWith(".zip")) return "application/x-zip";
else if(filename.endsWith(".gz")) return "application/x-gzip";
if(mySerial)
mySerial.println("getContentType FUNC");
return "text/plain";
} //end function getContentType
if(mySerial)
path += ".gz";
if(mySerial)
if(mySerial)
file.close();
if(mySerial)
return true;
} //end if
return false;
//File Upload for File System
void handleFileUpload(){
if(server.uri() != "/edit") return;
HTTPUpload& upload = server.upload();
if(upload.status == UPLOAD_FILE_START)
String filename = upload.filename;
if(!filename.startsWith("/"))
filename = "/"+filename;
if(mySerial)
mySerial.print("handleFileUpload Name: ");
mySerial.println(filename);
} //end if
fsUploadFile = SPIFFS.open(filename, "w");
filename = String();
} //end if
else if(upload.status == UPLOAD_FILE_WRITE)
if(mySerial)
mySerial.print("handleFileUpload Data: ");
mySerial.println(upload.currentSize);
} //end if
if(fsUploadFile)
fsUploadFile.write(upload.buf, upload.currentSize);
} //end else if
else if(upload.status == UPLOAD_FILE_END)
if(fsUploadFile)
fsUploadFile.close();
if(mySerial)
mySerial.print("handleFileUpload Size: ");
mySerial.println(upload.totalSize);
} //end if
} //end else if
} //end function handleFileUpload
//File Delete for File System
void handleFileDelete()
if(server.args() == 0) return server.send(500, "text/plain", "BAD ARGS");
String path = server.arg(0);
if(mySerial)
mySerial.println("handleFileDelete: " + path);
if(path == "/")
return server.send(500, "text/plain", "BAD PATH");
if(!SPIFFS.exists(path))
return server.send(404, "text/plain", "FileNotFound");
SPIFFS.remove(path);
path = String();
} //end function handleFileDelete
//File Create for File System
void handleFileCreate()
if(mySerial)
mySerial.println("handleFileCreate: " + path);
if(path == "/")
if(SPIFFS.exists(path))
return server.send(500, "text/plain", "FILE EXISTS");
File file = SPIFFS.open(path, "w");
if(file)
file.close();
return server.send(500, "text/plain", "CREATE FAILED");
path = String();
} //end function handleFileCreate
void handleFileList()
if(!server.hasArg("dir"))
return;
} //end if
String path = server.arg("dir");
if(mySerial)
mySerial.println("handleFileList: " + path);
Dir dir = SPIFFS.openDir(path);
path = String();
String output = "[";
while(dir.next())
File entry = dir.openFile("r");
if (output != "[") output += ',';
bool isDir = false;
output += "{\"type\":\"";
output += (isDir)?"dir":"file";
output += "\",\"name\":\"";
output += String(entry.name()).substring(1);
output += "\"}";
entry.close();
} //end while
output += "]";
server.send(200, "text/json", output);
} //end function handleFileList
//HHIO PTT POWER LED ON
void switchPOWERon() {
int powerStatusLength = 1;
subsys = SUBSYS_1;
//Account for the end of message
messageLength = powerStatusLength + 2;
messageContent = 1;
Serial.write(som);
Serial.write(eom);
} //end switchPOWERon
//HHIO PTT POWER LED OFF
void switchPOWERoff() {
subsys = SUBSYS_1;
messageContent = 0;
Serial.write(som);
Serial.write(eom);
} //end switchPOWERoff
//PUMP POWER ON
void pumpPOWERon() {
int pumpPowerStatusLength = 1;
subsys = SUBSYS_2;
messageLength = pumpPowerStatusLength + 2;
messageContent = 1;
Serial.write(som);
Serial.write(eom);
//PUMP POWER OFF
void pumpPOWERoff() {
subsys = SUBSYS_2;
messageContent = 0;
Serial.write(som);
Serial.write(eom);
//LED POWER ON
void switchLEDon() {
int ledStatusLength = 1;
subsys = SUBSYS_3;
messageLength = ledStatusLength + 2;
messageContent = 1;
Serial.write(som);
Serial.write(eom);
} //end switchLEDon
//LED POWER OFF
void switchLEDoff() {
subsys = SUBSYS_3;
messageContent = 0;
Serial.write(som);
Serial.write(eom);
} //end switchLEDoff
//Function to send all updated status values from arduino to the webpage
void statusUpdate(uint8_t num) {
//Valve C
if(currValveStatusNumC == 0)
} //end if
else if(currValveStatusNumC == 1)
valveColorC = "green";
valveTubePropsC = "350px solid #00ADEF";
valveStatusC = "Open";
} //end else if
//Valve D
if(currValveStatusNumD == 0)
} //end if
else if(currValveStatusNumD == 1)
valveColorD = "green";
valveTubePropsD = "350px solid #00ADEF";
valveStatusD = "Open";
} //end else if
//Valve E
if(currValveStatusNumE == 0)
} //end if
else if(currValveStatusNumE == 1)
valveColorE = "green";
valveTubePropsE = "350px solid #00ADEF";
valveStatusE = "Open";
} //end else if
String test = "";
test += currNumRefresh;
test += ",";
test += currMicroC;
test += ",";
test += currMicroD;
test += ",";
test += currMicroE;
test += ",";
test += currPressureC;
test += ",";
test += currPressureD;
test += ",";
test += currPressureE;
test += ",";
test += valveColorC;
test += ",";
test += valveTubePropsC;
test += ",";
test += valveStatusC;
test += ",";
test += valveColorD;
test += ",";
test += valveTubePropsD;
test += ",";
test += valveStatusD;
test += ",";
test += valveColorE;
test += ",";
test += valveTubePropsE;
test += ",";
test += valveStatusE;
test += ",";
test += currFluid;
test.toCharArray(statusbuf, 256);
webSocket.sendTXT(num, statusbuf, strlen(statusbuf));
} //end function statusUpdate
// Current POWER status
bool POWERStatus;
// Current LED status
bool LEDStatus;
// Commands sent through Web Socket
const char LEDON[] = "ledon";
const char LEDOFF[] = "ledoff";
const char teensyPOWERON[] = "teensyPOWERon";
const char teensyPOWEROFF[] = "teensyPOWERoff";
const char pumpPOWERON[] = "pumpPOWERon";
const char pumpPOWEROFF[] = "pumpPOWERoff";
const char teensyLEDON[] = "teensyLEDon";
const char teensyLEDOFF[] = "teensyLEDoff";
const char statusIdentifier[] = "Update Status";
//Websocket Event Function
void webSocketEvent(uint8_t num, WStype_t type, uint8_t * payload, size_t length)
//if(mySerial)
//mySerial.printf("webSocketEvent(%d, %d, ...)\r\n", num, type);
switch(type) {
case WStype_DISCONNECTED:
//if(mySerial)
//mySerial.printf("[%u] Disconnected!\r\n", num);
break;
case WStype_CONNECTED:
IPAddress ip = webSocket.remoteIP(num);
//if(mySerial)
//mySerial.printf("[%u] Connected from %d.%d.%d.%d url: %s\r\n", num, ip[0], ip[1], ip[2], ip[3], payload);
} //end case CONNECTED
break;
case WStype_TEXT:
//if(mySerial)
//mySerial.printf("[%u] get Text: %s\r\n", num, payload);
if(strcmp(teensyPOWERON, (const char *)payload) == 0) {
switchPOWERon();
} //end if
else if(strcmp(teensyPOWEROFF, (const char *)payload) == 0) {
switchPOWERoff();
} //end else if
else if(strcmp(pumpPOWERON, (const char *)payload) == 0) {
pumpPOWERon();
} //end else if
else if(strcmp(pumpPOWEROFF, (const char *)payload) == 0) {
pumpPOWERoff();
} //end else if
else if(strcmp(teensyLEDON, (const char *)payload) == 0) {
switchLEDon();
} //end else if
else if(strcmp(teensyLEDOFF, (const char *)payload) == 0) {
switchLEDoff();
} //end else if
else if(strcmp(statusIdentifier, (const char *)payload) == 0) {
statusUpdate(num);
} //end else if
if(mySerial)
mySerial.println("Unknown command");
} //end else
// send data to all connected clients
webSocket.broadcastTXT(payload, length);
break;
case WStype_BIN:
if(mySerial)
mySerial.printf("[%u] get binary length: %u\r\n", num, length);
hexdump(payload, length);
// echo data back to browser
webSocket.sendBIN(num, payload, length);
break;
default:
if(mySerial)
mySerial.printf("Invalid WStype [%d]\r\n", type);
break;
} //end switch
} //end function webSocketEventI also have included jQuery and this gauge library: https://github.com/Mikhus/canv-gauge.
Here's the complete list of files on the SPIFFS server currently:
I have not included the HTML/CSS/JS due to post size limit; if this would be helpful please let me know and I will post that code in a reply.
