warning: espcomm_sync failed
error: espcomm_open failed
error: espcomm_upload_mem failed
After a day of failed attemps I thought I could have broke it someway when flashing, it is so cheap that I just when to the store and buy another one. But the same error is still there. If I connect the new module in normal mode (GPIO0 HIGH) I can read using the Arduino IDE Serial Monitor it is ready and working:
Ai-Thinker Technology Co.,Ltd.
readyIm using an ESP-01 module and a Prolific USB-to-Serial Comm Port (COM4) that seems to work pretty good.
The Arduino IDE is configured as follows:
Board: SparkFun ESP8266 Thing
CPU Frecuency: 80MHz
Upload Speed: 115200
Port: COM4
Programmer: AVRISP mkll
This is the wiring I am using to program it:
As said, to start the module in normal operation, I open first the Arduino IDE Serial Monitor configured with NL& CR and 115200 bauds, then I press the reset button. All normal.
When I want to flash the ESP-01 module, I select "Upload" in Arduino, it starts compiling and then I press both RESET and GPIO0 buttons. Before the Arduino IDE shows "Uploading" I release the RESET button and maintain pressed GPIO0 button until it finish.
The complete log is here:
http://textuploader.com/53wz9
Any suggestions where the error could be ? Thanks.
