Please check out my KickStarter project.
https://www.kickstarter.com/projects/ha ... -thumb-imu
WiThumb is an Arduino compatible USB powered WiFi IoT developement board with 6 DOF IMU, precison temperature sensor and optional plastic case.
With WiThumb, adding WiFi, temperature sensor, Gyroscope and Accelerometer to your IoT project is a breeze. In addition, optional plastic case not only protects the circuits but also adds professional look to it. Why bother messy wiring or ugly project boxes while you can get this elegantly dressed up WiThumb.
In addition, WiThumb could be powered by standard USB type-A ports found in many power adapters, computers, TV, routers, cars, solar chargers and etc. It makes WiThumb an ideal device to deploy your applications anywhere.
Benefits
Compact (1.9 inch x 0.85 inch PCB)
USB Powered. Plug in anywhere.
Large community (Arduino, ESP8266 WiFi)
Easy to program
Easy to carry
Low cost
Low power (deep sleep mode)
Plastic case protects the electronics
Expandable
Specifications
32-bit MCU with 802.11b/g/n WiFi (ESP8266)
Integrated TCP/IP protocol stack
4MB Flash memory
Precision temperature sensor (+/- 0.25C typical accuracy)
6-axis Gyroscope + Accelerometer
IO pins: One 10-bit ADC, I2C and GPIOs
Breadboard friendly (0.1" pitch header holes)
Optional plastic case
