I have been talking to my ESP8266 module for a past few days after updating the firmware to 0018000902 on it. But, I am having a bit of uncertainty here updating data on thingspeak using their generated API or may be because of my lack of understanding on the usage "AT+CIPSEND" command. Below are steps I followed for the 1st trial:
AT+RST
OK
B1���:6�;�;!G��R��A#�
[System Ready, Vendor:www.ai-thinker.com]
AT+CWMODE?
+CWMODE:1
OK
AT+CIPMUX=1
OK
AT+CIPSTART=0,"TCP","api.thingspeak.com",80
OK
Linked
AT+CIPSEND=0,85
> GET https://api.thingspeak.com/update?api_k ... &field1=77
OK
Unlink
I have been following Kevin Darrah's tutorial https://www.youtube.com/watch?v=qU76yWHeQuw. When tried the above, the data field does not update.So, 1st trial failed!!!
But, when I did the below by changing the length of bytes assigned to CIPSEND command with 76, surprisingly the data was updated on thingspeak.
AT+RST
OK
�6B�=Cl��1�� �A#�+�A��
AT+CWMODE?
+CWMODE:1
OK
AT+CIPMUX=1
OK
AT+CIPSTART=4,"TCP","api.thingspeak.com",80
OK
Linked
AT+CIPSEND=4,76
SEND OK
+IPD,4,1:1
OK
OK
Unlink
So, the 2nd trial worked!!!
Again, I did a third trial and this time I changed the length of bytes assigned to the CIPSEND command to 100 as shown below:
OK
Linked
AT+CIPSEND=4,100
> GET https://api.thingspeak.com/update?api_k ... &field1=46
OK
Unlink
The only difference between the 3 trials is the length of bytes to send, assigned using "AT+CIPSEND". And the data is posted to thingspeak successfully only when the length of bytes is assigned as 76, but did not work when assigned with 85 and 100
