Hardware:
Hardware: ESP-12E
Core Version: 2.1.0-rc2
Description
I am working with MS5540Chttp://www.fut-electronics.com/wp-content/uploads/2015/08/MS5540C_waterproof_pressure_sensor_datasheet.pdf sensor, trying to communicate with it using SPI, but getting wrong data and the same result regardless the environment changes.
I set the SPI Frequency to 500khz
SPI.setFrequency(500000);I used to make this in arduino using this line of code
SPI.setClockDivider(SPI_CLOCK_DIV32);I also uses a pwm frequency (mclk) using:
analogWriteFreq(10);
analogWriteRange(256);
analogWrite(D8, 128);
I used to write that arduino uno using:
TCCR1B = (TCCR1B & 0xF8) | 1 ;
analogWrite(9, 128);
Why am I getting wrong reads ??
What Should I have to change to get write reads from the sensor.
Settings in IDE
Module: NodeMCU 1.0 (ESP-12E Module)
Flash Size: 4MB
CPU Frequency: 80Mhz
Upload Using: SERIAL
Sketch:
#include <SPI.h>
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
#include <WiFiClientSecure.h>
#include <ArduinoJson.h>
#include "FS.h"
Serial.println("");
delay(2000);
setupSensor();
readSensorData();
delay(1000);
void resetsensor() //this function keeps the sketch a little shorter
SPI.setDataMode(SPI_MODE0);
SPI.transfer(0x15);
SPI.transfer(0x55);
SPI.transfer(0x40);
void setupSensor() {
SPI.begin(); //see SPI library details on arduino.cc for details
SPI.setBitOrder(MSBFIRST);
// SPI.setClockDivider(SPI_CLOCK_DIV32); //divide 16 MHz to communicate on 500 kHz (16000000/32)
// 80,000,000 /
// SPI.beginTransaction(SPISettings(500000, MSBFIRST, SPI_MODE0));
// SPI.setHwCs(false);
pinMode(clock, OUTPUT);
delay(100);
int readSensorData() {
#ifdef __AVR__
TCCR1B = (TCCR1B & 0xF8) | 1 ; //generates the MCKL signal
Serial.println("HAHAHA d7kt 3leek");
#else
#endif
resetsensor();//resets the sensor - caution: afterwards mode = SPI_MODE0!
//Calibration word 1
unsigned int word1 = 0;
unsigned int word11 = 0;
SPI.transfer(0x1D); //send first byte of command to get calibration word 1
SPI.transfer(0x50); //send second byte of command to get calibration word 1
SPI.setDataMode(SPI_MODE1); //change mode in order to listen
word1 = SPI.transfer(0x00); //send dummy byte to read first byte of word
word1 = word1 << 8; //shift returned byte
word11 = SPI.transfer(0x00); //send dummy byte to read second byte of word
word1 = word1 | word11; //combine first and second byte of word
//Calibration word 2; see comments on calibration word 1
unsigned int word2 = 0;
byte word22 = 0;
SPI.transfer(0x1D);
SPI.transfer(0x60);
word2 = SPI.transfer(0x00);
word2 = word2 <<8;
word22 = SPI.transfer(0x00);
word2 = word2 | word22;
//Calibration word 3; see comments on calibration word 1
unsigned int word3 = 0;
byte word33 = 0;
SPI.transfer(0x1D);
SPI.transfer(0x90);
word3 = SPI.transfer(0x00);
word3 = word3 <<8;
word33 = SPI.transfer(0x00);
word3 = word3 | word33;
//Calibration word 4; see comments on calibration word 1
unsigned int word4 = 0;
byte word44 = 0;
SPI.transfer(0x1D);
SPI.transfer(0xA0);
word4 = SPI.transfer(0x00);
word4 = word4 <<8;
word44 = SPI.transfer(0x00);
word4 = word4 | word44;
long c1 = word1 >> 1;
long c2 = ((word3 & 0x3F) << 6) | ((word4 & 0x3F));
long c3 = (word4 >> 6) ;
long c4 = (word3 >> 6);
long c5 = (word2 >> 6) | ((word1 & 0x1) << 10);
long c6 = word2 & 0x3F;
//Temperature:
unsigned int tempMSB = 0; //first byte of value
unsigned int tempLSB = 0; //last byte of value
unsigned int D2 = 0;
SPI.transfer(0x0F); //send first byte of command to get temperature value
SPI.transfer(0x20); //send second byte of command to get temperature value
delay(35); //wait for conversion end
tempMSB = SPI.transfer(0x00); //send dummy byte to read first byte of value
tempMSB = tempMSB << 8; //shift first byte
tempLSB = SPI.transfer(0x00); //send dummy byte to read second byte of value
D2 = tempMSB | tempLSB; //combine first and second byte of value
//Pressure:
unsigned int presMSB = 0; //first byte of value
unsigned int presLSB =0; //last byte of value
unsigned int D1 = 0;
SPI.transfer(0x0F); //send first byte of command to get pressure value
SPI.transfer(0x40); //send second byte of command to get pressure value
presMSB = SPI.transfer(0x00); //send dummy byte to read first byte of value
presMSB = presMSB << 8; //shift first byte
presLSB = SPI.transfer(0x00); //send dummy byte to read second byte of value
D1 = presMSB | presLSB;
const long UT1 = (c5 * 8) + 20224;
const long dT =(D2 - UT1);
const long TEMP = 200 + ((dT * (c6 + 50))/1024);
const long OFF = (c2*4) + (((c4 - 512) * dT)/4096);
const long SENS = c1 + ((c3 * dT)/1024) + 24576;
long PCOMP = ((((SENS * (D1 - 7168))/16384)- OFF)/32)+250;
// float TEMPREAL = TEMP/10;
Serial.print("pressure = ");
Serial.print(PCOMP);
Serial.println(" mbar");
const long dT2 = dT - ((dT >> 7 * dT >> 7) >> 3);
const float TEMPCOMP = (200 + (dT2*(c6+100) >>11))/10;
Serial.print("temperature = ");
Serial.print(TEMPCOMP);
Serial.println(" °C");
Serial.println("************************************");
analogWriteFreq(1000);
analogWriteRange(PWMRANGE);
return PCOMP; // in mbar
