This is not tested yet. I just start to play with my nodemcu.
If you code nodemcu using the Arduino IDE you may use
... fragment Arduino Board
// Arduino Code
#include <SoftwareSerial.h>
SoftwareSerial mySerial(7, 8); // RX, TX on nodemcu
... fragment nodemcu Board
// nodemcu Code
SoftwareSerial mySerial(8, 7); // RX, TX on Arduino
Connect 7 to 8 and 8 to 7 but you need a level converter (3.3v mode nodemcu) to protect the
nodemcu input pins.
At least you implement a communication protocol to send data between both boards.
f41*
ketsayay2538 wrote:Could anyone suggest How to communicate between node MCU and Arduino by using serial communication for send some char or int
This is the overview of the basic methods
Ray
SoftwareSerial mySerial(13, 15); // RX, TX nodemcu
Serial.begin(9600);
mySerial.begin(9600);
pinMode(13,OUTPUT);
char dato = Serial.read();
char dato2 = mySerial.read();
int tiempo = 100;
if (dato == 'S'){
mySerial.write(45);
digitalWrite(13, HIGH);
Serial.println("LETRA S ENVIADA");
if (dato == 'A'){
mySerial.write(58);
digitalWrite(13, LOW);
Serial.println("LETRA A ENVIADA");
if (dato2 == 58){
Serial.println("LETRA S RECIBIDA");
if (dato2 == 45){
Serial.println("LETRA A RECIBIDA");
