Page 1 of 6
Looking for Battery Saver
PostPosted: Tue Jul 19, 2016 2:50 pm
by JerryESPN
Hey there,
currently i´m using this Setup:
ESP-01, DHT-11, LD1117V33, 3,7V Li-Po 2400mAh
Working Sketch:
Code: Select all#include <DHT.h>
// replace with your channel’s thingspeak API key,
String apiKey = "[ThingSpeakAPIKey]";
const char* ssid = "[SSID]";
const char* password = "[password]";
const char* server = "api.thingspeak.com";
#define DHTPIN 2 // what pin we’re connected to
DHT dht(DHTPIN, DHT11,15);
WiFiClient client;
delay(10);
dht.begin();
WiFi.begin(ssid, password);
Serial.println(ssid);
Serial.println("");
float h = dht.readHumidity();
float t = dht.readTemperature();
if (isnan(h) || isnan(t)) {
Serial.println("Failed to read from DHT sensor!");
return;
if (client.connect(server,80)) { // "184.106.153.149" or api.thingspeak.com
String postStr = apiKey;
postStr +="&field1=";
postStr += String(t);
postStr +="&field2=";
postStr += String(h);
postStr += "\r\n\r\n";
client.print("POST /update HTTP/1.1\n");
client.print("Host: api.thingspeak.com\n");
client.print("Connection: close\n");
client.print("X-THINGSPEAKAPIKEY: "+apiKey+"\n");
client.print("Content-Type: application/x-www-form-urlencoded\n");
client.print("Content-Length: ");
client.print(postStr.length());
client.print("\n\n");
client.print(postStr);
Serial.print(t);
Serial.print(" degrees Celcius Humidity: ");
Serial.print(h);
Serial.println("% send to Thingspeak");
client.stop();
Serial.println("Waiting…");
// thingspeak needs minimum 15 sec delay between updates
delay(20000);
Problem:
Battery empty after 6h.
Question:
Any Ideas what to do to get a better battery life?
I look forward to any advice! Thanks!
Greetings,
JerryESPN
Re: Looking for Battery Saver
PostPosted: Wed Jul 20, 2016 1:59 am
by eduperez
Please, have a look at any of the post about using batteries in this forum, there is lots of information available. For starters, you are keeping the WiFi on at all times, and that is a big no-no; you are not using any form of deep sleep, also.
PostPosted: Wed Jul 20, 2016 8:50 am
by Ken Shaw
The esp8266-01 doesn't have the pins broken out, but you can solder to them, or get a larger esp8266 module to be able to activate deep sleep etc.
PostPosted: Wed Jul 20, 2016 9:29 am
by schufti
I'm not sure, there are new ones that show a paint blob near the pinheader that covers sth resembling a smd resistor... maybe they installed the required resistor by default? Wouldn't interfere with std usage.
