By Mikecay
#52631 Hi All,
I am trying to read the voltage from a 6v solar panel using an ESP-12. I have a voltage divider made up of a 10k and 2k resistor. When I did my testing my voltmeter was reading 5v from the solar panel and analogread(A0) is giving me 803, from that I calculate 803/1024 * 6 to me 4.705v. This is a 6 to 7% difference, which I find pretty big. What could be causing such a large variation?
Mike
By trackerj
#52638 Hi Mike,
What is your Measured Full scale voltage for your ADC input? This varies depending on the VCC value so might have some error from there.
Also I think I will choose the resistors a bit higher in values, like 54k/10k. This will give you a confortable max input voltage of about 0.938V for a 6V input.
For more details about ADC and voltage divider might worth to take a look at the Internal ADC - ESP8266 post. Take a look also at the comments, few good examples also there.
By Mikecay
#52662
trackerj wrote:What is your Measured Full scale voltage for your ADC input?
Are you referring to the actual voltage on the ADC rather than the calculated voltage based in Vin * (R2/(R1+R2))? I have not measured it but I guess it probably is not exactly 1v. I will increase the resistor sizes and check the actual voltage on the ADC pin. I also read carefully the site you linked to. A quick passed showed there was a lot they were considering that I was not.
Thank you for your help.
By rudy
#52664 The 1 volt reference is not made to supply an accurate reference for use with an A/D converter. The 1 volt is used for internal level and biasing functions. It is only being made available for the A/D converter because it already existed. Think of the reference as a byproduct of a different process.
