By billm9
#53744 Having issues Homie not picking up the temperature from DS18B20. If i do it without Homie and print to serial, it works perfectly.
With Homie, does not even print on serial.
Here is my sketch.
Thanks
Code: Select all#include <Homie.h>
#include <OneWire.h>
#include <DallasTemperature.h>
#define FW_NAME "temperature"
#define FW_VERSION "1.0.0"
const int TEMPERATURE_INTERVAL = 300;
unsigned long lastTemperatureSent = 0;
#define ONE_WIRE_BUS    2  // DS18B20 pin
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature DS18B20(&oneWire);
HomieNode temperatureNode("temperature", "temperature");
void setupHandler() {
  Homie.setNodeProperty(temperatureNode, "unit", "f", true);
void loopHandler() {
  if (millis() - lastTemperatureSent >= TEMPERATURE_INTERVAL * 1000UL || lastTemperatureSent == 0) {
    float temperature = 22; // Fake temperature here, for the example
    DS18B20.requestTemperatures();
    temperature = DS18B20.getTempFByIndex(0);
    Serial.print("Temperature: ");
    Serial.print(temperature);
    Serial.println(" °F");
    if (Homie.setNodeProperty(temperatureNode, "degrees", String(temperature), true)) {
      lastTemperatureSent = millis();
    } else {
      Serial.println("Temperature sending failed");
  Serial.begin(9600);
  Serial.println(FW_NAME FW_VERSION);
  DS18B20.begin();
  Homie.setFirmware(FW_NAME, FW_VERSION);
  Homie.registerNode(temperatureNode);
  Homie.setSetupFunction(setupHandler);
  Homie.setLoopFunction(loopHandler);
  Homie.setup();
  Homie.loop();
