I'm having problems getting the breakout to work. First I want to get initialization working. MCP_CAN::Begin function returns error.
This breakout board has 8MHZ crystal. I wonder if I have to make some extra setup for 8MHZ SPI to work or what is the default speed for SPI in ESP8266 Arduino ?
I took a look at the library codes:
MCP_CAN::begin function has clock speed in its parameters and it calls function:
INT8U MCP_CAN::mcp2515_init(const INT8U canIDMode, const INT8U canSpeed, const INT8U canClock)however
canClock res = mcp2515_setCANCTRL_Mode(MODE_CONFIG);.. and call fails and returns the error.
So to me it seems no SPI clock setting is done in the library before SPI.transfer function. Should I set the frequency (how) myself at some point in my sketch ?
Here's my sketch
#include <mcp_can.h>
#include <mcp_can_dfs.h>
#include <SPI.h>
#define CAN0_INT D2 // Set INT to pin D2
esp8266 SPI CS (CMD) GPIO15 taken from:
http://www.esp8266.com/wiki/doku.php?id=esp8266_gpio_pin_allocations
MCP_CAN CAN0(15);
void setup()
// Initialize MCP2515 running at 16MHz with a baudrate of 500kb/s and the masks and filters disabled.
if(CAN0.begin(MCP_ANY, CAN_500KBPS, MCP_8MHZ) == CAN_OK)
Serial.println("MCP2515 Initialized Successfully!");
Serial.println("Error Initializing MCP2515...");
CAN0.setMode(MCP_NORMAL); // Set operation mode to normal so the MCP2515 sends acks to received data.
pinMode(CAN0_INT, INPUT); // Configuring pin for /INT input
void loop()
yield();
