By mostafa khedrawy
#54383 what is wrong ? i cant receive any data
#include <WiFiUDP.h>
char* ssid = "TE-Data";
//your wifi name or ssid
char* password = "0544835550";
//your wifi password
int mine[400];
// arrey that contain mins
bool connectToWifi(char*,char*,IPAddress);
bool sendDATA(IPAddress sendip ,char* sendBuffer,int port);
int reseveDATA(IPAddress myip ,char* reseveBuffer,int port);
IPAddress myip(192, 168, 1, 7);     // NETWORK: Static myip details...    // myipAddress is object for ip so you can use ip in function
IPAddress  sendip(192,168,1,4);
WiFiUDP Udp;
char* sendBuffer="hi";
char reseveBuffer[255];
  delay(10);
 connectToWifi(ssid,password,myip);
//sendDATA(sendip ,sendBuffer,8015);
int tem =reseveDATA(myip,reseveBuffer,8015);
bool connectToWifi(char* ssid ,char* password,IPAddress myip)
    IPAddress  gateway(192, 168, 1, 1);
    IPAddress  subnet(255, 255, 255, 0);
    // that function make connection to the rourter with bassfic myip
    Serial.println(ssid);
    //for dubbigig only
    WiFi.begin(ssid, password);
        Serial.print(".");
    Serial.println("\"");
    Serial.println("WiFi connected to ip :");
    Udp.beginPacket(sendip, port);
    Udp.write(sendBuffer);
    bool bol= Udp.endPacket();
    return (bol);
      Udp.beginMulticast(WiFi.localIP(),sendip , port);
      IPAddress  remote = Udp.remoteIP();
      int no;
      if(no = Udp.parsePacket())
        Udp.read(reseveBuffer, no);
        for (int i=0;i<no;i++)
           Serial.println(reseveBuffer[i-1]);
      return (no);
