I try to configure my router to N Channel for make connection more fast, but when i change the router to N channel, ESP can't connect to router
this is picture when the channel was B/G/N
and when i change the band to only N, all ESP can't connect
Explore... Chat... Share...
802.11n[edit]
Main article: IEEE 802.11n-2009
802.11n is an amendment that improves upon the previous 802.11 standards by adding multiple-input multiple-output antennas (MIMO). 802.11n operates on both the 2.4 GHz and the 5 GHz bands. Support for 5 GHz bands is optional. It operates at a maximum net data rate from 54 Mbit/s to 600 Mbit/s. The IEEE has approved the amendment, and it was published in October 2009.[15][16] Prior to the final ratification, enterprises were already migrating to 802.11n networks based on the Wi-Fi Alliance's certification of products conforming to a 2007 draft of the 802.11n proposal.
