I want to add sensor data to a mysql database, and it works from a browser, my problem is i have trouble creating the "web request" that i need to do.
The sensor data comes from a DHT22 sensor, i was able to post to "thing speak" before i modified the sketch
serial output
0 Temperature: 21.80
0 Humidity: 72.20
0 VCC: 3.19
WiFi Client connected
Entering deep sleep
So the data is present.
if i just use this the "fake" data is being inserted into the SQL database, so i know the PHP part is working
http://192.168.1.250/default.php?sensor=havestue&temp=23.1&hum=60.3&voltage=3.32
And in the webserver i can see that its being contacted
from apache2 access.log
127.0.1.1:80 192.168.1.93 - - [07/Sep/2016:20:22:11 +0200] "GET /default.php?sensor=havestue&temp=21.40&hum=73.20&voltage=3.19" 200 0 "-" "-"
modified thingspeak code
if (client.connect(server, 80)) { // use ip 184.106.153.149 or api.thingspeak.com
Serial.println("WiFi Client connected ");
String postStr;
postStr += "?sensor=";
postStr += String(sensorname);
postStr += "&temp=";
postStr += String(temp);
postStr += "&hum=";
postStr += String(hum);
postStr += "&voltage=";
postStr += String(vcc);
postStr += "\r\n\r\n";
client.print("GET /default.php");
client.print(postStr);
client.print(" HTTP/1.1\n");
client.print("Host: 192.168.1.250\n");
client.print("Connection: close\n");
client.print("Content-Type: application/x-www-form-urlencoded\n");
client.print("Content-Length: ");
client.print(postStr.length());
client.print("\n\n");
// client.print(postStr);
}//end if
sent++;
client.stop();I guess my forming of the request is all off, Can anyone help me figure out where i have screwed up?
Best Regards
Lasse
