Send 433mhz decoded signal to internet
PostPosted: Sun Sep 11, 2016 8:48 am
by darko1984
Hi guys,
i have a question for you..
I'have developed code to decode weather data from a weather station(wind,rain,temperature,solar radiation) that send packet at 433mhz.
I'm using a 433mhz rx and an arduino nano,it works perfectly,after i receive the data,i send it to the hardware serial monitor ,so i can read data from serial console
of arduino ide.
Now,i would like to send this data to a server using an esp8266.
Is it possible send data from hardware serial monitor of arduino,to internet,using esp8266-01?
Could you pease give me some hints?Thank you guys!
This is the code that i'm using to send data so hardware serial monitor.
Code: Select all#ifdef SERIALOG
void SerialWrite(byte bSensorType)
  byte b_ch;
  switch(bSensorType)
  case 0: //temp
      b_ch=(bICP_DEA_PacketData[bICP_WSR_PacketOutputPointer][4] & 0x0C) >> 2;
      Serial.print(b_ch,DEC );
      Serial.print(" ");
      Serial.print(W_Packet.Temp[b_ch].temp/10, DEC );
      Serial.write( byte('.') );
      if( W_Packet.Temp[b_ch].temp < 0 )
      Serial.print(((0-W_Packet.Temp[b_ch].temp)%10), DEC );
      else
      Serial.print( W_Packet.Temp[b_ch].temp%10, DEC );
      Serial.print(" ");
      Serial.print(W_Packet.Temp[b_ch].hr, DEC );
      Serial.print(" ");
#ifdef BAROMETER_SENSOR
      Serial.print(pressure/100, DEC);
      Serial.print( pressure%100, DEC);
#endif
      break;
  case 1: //Rain
      Serial.print("4");
      Serial.print(" ");
      Serial.print(uiWSR_RainfallCount/4, DEC );
      Serial.print(uiWSR_RainfallCount%4, DEC );
      break;
  case 2: //wind
      if((W_Packet.isfully & 0xC0) == 0xC0)
        //avg_wind
        Serial.print("2");
        Serial.print(" ");
        Serial.print( W_Packet.Wind.avg/5, DEC );
        Serial.print(W_Packet.Wind.avg%5, DEC );
        Serial.print(" ");
        //gust_wind
        Serial.print(W_Packet.Wind.gst/5, DEC );
        Serial.print(W_Packet.Wind.gst%5, DEC );
        Serial.print(" ");
        //wind_dir
        Serial.print(W_Packet.Wind.dir);
      break;
  case 3: //SolarRadiation
      if((W_Packet.SolarRad<18000) && (bWSR_StationTransmitterID == 156))
        Serial.print( "StationID=" );
        Serial.print( bWSR_StationTransmitterID, DEC );
        Serial.print(",Solar Radiation=");
        Serial.print( W_Packet.SolarRad/10, DEC );
        Serial.print( W_Packet.SolarRad%10, DEC );
        Serial.print(" W/mq");
      break;
#endif
Re: Send 433mhz decoded signal to internet
PostPosted: Sun Sep 11, 2016 12:09 pm
by AcmeUK
How do you want to send the data? UDP, HTTP Put/Post/GET, MQTT?
Have a look at this https://github.com/tuanpmt/espduino
It implements communication with the ESP from the Arduino via the serial port using SLIP protocol. The page has MQTT and REST examples.
PostPosted: Sun Sep 11, 2016 12:29 pm
by darko1984
AcmeUK wrote:How do you want to send the data? UDP, HTTP Put/Post/GET, MQTT?
Thanks acme!
I would like to send data with an http post and then intercept it in php,saving the record to a mysql database!
I Will check espduino and let you know ;)
