By BlueEther
#56679 I got a few D1 clones https://www.aliexpress.com/item/5sets-D ... 26305.html and cant get the Arduino IDE to flash a working sketch to them. The flash looks to complete without error but on a reset they go into a bootloop with the following error:
Code: Select all ets Jan  8 2013,rst cause:2, boot mode:(3,6)
tail 8
chksum 0x2d
csum 0x2d
v00000000
~ld
tail 8
chksum 0x2d
csum 0x2d
v00000000
~ld
Exception (28):
epc1=0x4021454a epc2=0x00000000 epc3=0x00000000 excvaddr=0x00000000 depc=0x00000000
ctx: sys
sp: 3ffffa70 end: 3fffffb0 offset: 01a0
>>>stack>>>
3ffffc10:  00000000 ffffffff ffffffff ffffffff
3ffffc20:  ffffffff ffffffff ffffffff ffffffff
3ffffc30:  ffffffff 000001ff ffffff04 ffff0001
3ffffc40:  0000000e 65756c42 65687445 65542072
3ffffc50:  ef006863 efeffefe efeffefe efeffefe
3ffffc60:  efeffefe 6c697769 746f6e6c 65766967
3ffffc70:  6d756f79 79656b79 1004d800 201afe40
3ffffc80:  ff09c440 ff09943f 201c7c3f 01c20040
3ffffc90:  00001c00 00000300 ff09ac00 efeffe3f
3ffffca0:  efeffefe ffffffff ffffffff ffffffff
3ffffcb0:  ffffffff ffffffff ffffffff ffffffff
3ffffcc0:  ffffffff ffffffff ffffffff ffffffff
3ffffcd0:  ffffffff ffffffff ffffffff ffffffff
3ffffce0:  ffffffff ffffffff ffffffff ffffffff
3ffffcf0:  ffffffff ffffffff ffffffff ffffffff
3ffffd00:  ffffffff ffffffff ffffffff ffffffff
3ffffd10:  ffffffff ffffffff ffffffff ffffffff
3ffffd20:  ffffffff ffffffff ffffffff ffffffff
3ffffd30:  ffffffff ffffffff ffffffff ffffffff
3ffffd40:  ffffffff ffffffff ffffffff ffffffff
3ffffd50:  ffffffff ffffffff ffffffff ffffffff
3ffffd60:  ffffffff ffffffff ffffffff ffffffff
3ffffd70:  ffffffff ffffffff ffffffff ffffffff
3ffffd80:  ffffffff ffffffff ffffffff ffffffff
3ffffd90:  ffffffff ffffffff ffffffff ffffffff
3ffffda0:  ffffffff ffffffff ffffffff ffffffff
3ffffdb0:  ffffffff ffffffff ffffffff ffffffff
3ffffdc0:  ffffffff ffffffff ffffffff ffffffff
3ffffdd0:  ffffffff ffffffff ffffffff ffffffff
3ffffde0:  ffffffff ffffffff ffffffff ffffffff
3ffffdf0:  ffffffff ffffffff ffffffff ffffffff
3ffffe00:  ffffffff ffffffff ffffffff ffffffff
3ffffe10:  ffffffff ffffffff ffffffff ffffffff
3ffffe20:  ffffffff ffffffff ffffffff ffffffff
3ffffe30:  ffffffff 04080000 001c110c 01010000
3ffffe40:  ffffffff 00000003 ffffff00 ffffffff
3ffffe50:  ffffffff ffffffff ffffffff ffffffff
3ffffe60:  ffffffff ffffffff ffffffff ffff0064
3ffffe70:  ffffffff ffffffff ffffffff ffffffff
3ffffe80:  ffffffff ffffffff ffffffff ffffffff
3ffffe90:  ffffffff ffffffff ffffffff ffffffff
3ffffea0:  ffffffff ffffffff ffffffff ffffffff
3ffffeb0:  ffffffff ffffffff ffffffff ffffffff
3ffffec0:  ffffffff ffffffff ffffffff ffffffff
3ffffed0:  ffffffff ffffffff ffffffff ffffffff
3ffffee0:  ffffffff ffffffff ffffffff ffffffff
3ffffef0:  ffffffff ffffffff ffffffff ffffffff
3fffff00:  ffffffff ffffffff ffffffff ffffffff
3fffff10:  ffffffff ffffffff ffffffff ffffffff
3fffff20:  ffffffff ffffffff ffffffff ffffffff
3fffff30:  ffffffff ffffffff ffffffff ffffffff
3fffff40:  ffffffff ffffffff ffffffff ffffffff
3fffff50:  ffffffff ffffffff ffffffff ffffffff
3fffff60:  ffffffff ffffffff ffffffff ffffffff
3fffff70:  ffffffff ffffffff ffffffff ffffffff
3fffff80:  ffffffff ffffffff ffffffff ffffffff
3fffff90:  ffffffff 2fd08f3d fd7cc865 08a2bbd5
3fffffa0:  400201e9 fb5a45f5 ffffff00 55aa55aa
<<<stack<<<
But if I reflash NodeMCU to the units I can get Lua scripts to run so the modules seem fine:
Code: Select allNodeMCU 0.9.5 build 20150318  powered by Lua 5.1.4
lua: cannot open init.lua
> function listap(t)
>>       for ssid,v in pairs(t) do
>>         authmode, rssi, bssid, channel =
>>           string.match(v, "(%d),(-?%d+),(%x%x:%x%x:%x%x:%x%x:%x%x:%x%x),(%d+)")
>>         print(ssid,authmode,rssi,bssid,channel)
>>       end
>>       end
> wifi.sta.getap(listap)
> SPARK-TGN3LV   4   -84   f8:23:b2:6d:44:c4   8
BlueEther Tech   4   -56   c8:0e:14:42:30:88   12
I have tried different modules/speeds/settings but nothing seems to work to get an arduino script ro work
thanks
Charles
By BlueEther
#56888 Well I must say that this is embarrassing, after nearly a week of trying to get to the bottom (I could flash the two nodeMCU that I have just fine) I decided to uninstall/reinstall the esp8266 board from the board manager and all works fine.
