-Brad
ESP8266 Arduino Code
#include <WiFiUDP.h>
#include <Time.h>
const char* ssid = XXXX;
const char* password = XXXX;
IPAddress ip(192, 168, 1, 158);
IPAddress gateway(192, 168, 1, 1);
IPAddress subnet(255, 255, 255, 0);
unsigned int port = 2000;
int replyWait = 5000;
// buffers for receiving and sending data
char packetBuffer[32]; //buffer to hold incoming packet,
char ReplyBuffer[] = "acknowledged"; // a string to send back
bool lightStatus = 0;
WiFiUDP Udp;
IPAddress ham(192,168,1,10);
int lastMinUpdate = 0;
bool replyExpected = false;
int lastCycleMin = 0;
int triac = 14;
int greenLED = 12;
int redLED = 13;
int overrideSw = 16;
pinMode(triac,OUTPUT);
pinMode(greenLED,OUTPUT);
pinMode(redLED,OUTPUT);
pinMode(overrideSw,INPUT);
digitalWrite(triac,LOW);
digitalWrite(greenLED,LOW);
digitalWrite(redLED,LOW);
delay(10);
// Connect to WiFi network
Serial.println(ssid);
bool ledToggle = true;
WiFi.config(ip, gateway, subnet);
WiFi.begin(ssid, password);
digitalWrite(redLED,ledToggle);
ledToggle = !ledToggle;
Serial.print(".");
Serial.println("");
digitalWrite(redLED,HIGH);
// Print the IP address
Serial.print("Using IP: ");
Serial.println("Initializing UDP Interface...");
Udp.begin(port);
Serial.print("Done, Listening on port ");
Serial.println(port,DEC);
Serial.println("Syncing Clock with HAM...");
sprintf(packetBuffer,"TIME?");
Udp.beginPacket(ham, port);
Udp.write(packetBuffer);
Udp.endPacket();
replyExpected = true;
int replyTimeout = millis() + replyWait;
while (replyExpected && (millis() < replyTimeout))
checkUDP();
if (replyExpected)
replyTimeout = 0;
void parseClock()
int mth = atoi(&packetBuffer[5]);
Serial.print(mth,DEC);
Serial.print("/");
int da = atoi(&packetBuffer[8]);
Serial.print(da,DEC);
Serial.print("/");
int yr = atoi(&packetBuffer[11]);
Serial.print(yr,DEC);
Serial.print(" ");
int hr = atoi(&packetBuffer[16]);
Serial.print(hr,DEC);
Serial.print(":");
int mi = atoi(&packetBuffer[19]);
Serial.print(mi,DEC);
Serial.print(":");
int se = atoi(&packetBuffer[22]);
Serial.print(se,DEC);
setTime(hr,mi,se,da,mth,yr);
Serial.println(" Time is Set");
* Reads and parses data in UDP buffer
void udpRead(int packetSize)
bool ack = true;
clearArray();
Serial.print("Received packet of size ");
Serial.print(packetSize,DEC);
Serial.print(" from ");
IPAddress remote = Udp.remoteIP();
for (int i = 0; i < 4; i++)
Serial.print(remote[i], DEC);
if (i < 3)
Serial.print(".");
Serial.print(", port ");
Serial.println(Udp.remotePort());
// read the packet into packetBufffer
Udp.read(packetBuffer, 32);
Udp.flush();
Serial.println("Contents:");
Serial.println(packetBuffer);
* parse UDP data
char *ptr;
ptr = strstr(packetBuffer,"TIME");
if (ptr != NULL)
parseClock();
else if (strcmp(packetBuffer, "LIGHT_OFF")==0)
lightStatus = 0;
Serial.println("Light Off");
else if (strcmp(packetBuffer, "LIGHT_ON")==0)
lightStatus = 1;
Serial.println("Light On");
else if (strcmp(packetBuffer, "STATUS?")==0)
Serial.println("Sending Status");
ack = false;
clearArray();
if (lightStatus)
sprintf(packetBuffer,"LIGHT_ON");
sprintf(packetBuffer,"LIGHT_OFF");
Udp.beginPacket(Udp.remoteIP(), port);
Udp.endPacket();
if (ack && (strcmp(packetBuffer,"acknowledged") != 0))
// send a reply, to the IP address and port that sent us the packet we received
Udp.write(ReplyBuffer);
Udp.endPacket();
* Clears the buffer from previous UDP read
void clearArray(){
for( int i = 0; i < 30; ++i ){
packetBuffer[i] = (char)0;
packetBuffer[31] = '/0';
void checkUDP()
* Check for udp data
int packetSize = Udp.parsePacket();
//Serial.println(packetSize,DEC);
if (packetSize)
Serial.print("Packet Size: ");
if (packetSize > 0 && packetSize < 33)
Serial.println("Reading Packet");
udpRead(packetSize);
Serial.print("Flushing Packet... ");
Udp.flush();
Serial.println(" Packet Flushed");
void loop()
if (WiFi.status() == WL_CONNECTED)
//esp.restart()
checkUDP();
if (lightStatus)
digitalWrite(triac,HIGH);
digitalWrite(greenLED,HIGH);
//code added to verify loop is still running
int minNow = minute();
if (abs(minNow - lastCycleMin) >= 1)
Serial.print(".");
Serial.print(minNow);
lastCycleMin = minNow;
if (minNow % 15 == 0 && minNow != lastMinUpdate)
char clockBuffer[20];
if (isAM())
sprintf(clockBuffer,"%02u/%02u/%02u %u:%02u AM ",month(),day(),year(),hourFormat12(),minute());
sprintf(clockBuffer,"%02u/%02u/%02u %u:%02u PM ",month(),day(),year(),hourFormat12(),minute());
Serial.println("...");
Serial.print("Running ");
Serial.println(clockBuffer);
lastMinUpdate = minNow;
}Serial Output From my last test run:
Connecting to NachoWifi
WiFi connected
Using IP: 192.168.1.158
Done, Listening on port 2000
Packet Size: 24
Reading Packet
Received packet of size 24 from 192.168.1.10, port 58712
Contents:
TIME 10/22/2016 15:55:31
10/22/2016 15:55:31 Time is Set
.55.56.57.58.59.0.1.2.3.4.5.6.7.8.9.10.11.12.13.14.15...
Running 10/22/2016 4:15 PM
.16.17.18.19.20.21.22.23.24.25.26.27.28.29.30...
Running 10/22/2016 4:30 PM
.31.32.33.34.35.36.37.38.39.40.41.42.43.44.45...
Running 10/22/2016 4:45 PM
.46.47.48.49.50.51.52.53.54.55.56.57.58.59.0...
Running 10/22/2016 5:00 PM
Running 10/22/2016 5:15 PM
Running 10/22/2016 5:30 PM
Running 10/22/2016 5:45 PM
Running 10/22/2016 6:00 PM
Running 10/22/2016 6:15 PM
Running 10/22/2016 6:30 PM
Running 10/22/2016 6:45 PM
Running 10/22/2016 7:00 PM
.1.2.3.4
<At 76800 BAUD>
load 0x4010f000, len 1264, room 16
tail 0
chksum 0x42
csum 0x42
<Back to 115200 BAUD>
WiFi connected
Packet Size: 24
Reading Packet
Contents:
TIME 10/22/2016 19:05:01
10/22/2016 19:5:1 Time is Set
.5Packet Size: 8
Reading Packet
Received packet of size 8 from 192.168.1.55, port 61877
Contents:
LIGHT_ON
Light On
Packet Size: 7
Reading Packet
Received packet of size 7 from 192.168.1.55, port 61877
Contents:
STATUS?
Sending Status
Packet Size: 9
Reading Packet
Received packet of size 9 from 192.168.1.55, port 61877
Contents:
LIGHT_OFF
Light Off
Packet Size: 7
Reading Packet
Contents:
STATUS?
Sending Status
Packet Size: 8
Reading Packet
Contents:
LIGHT_ON
Light On
Packet Size: 7
Reading Packet
Contents:
STATUS?
Sending Status
Packet Size: 7
Reading Packet
Contents:
STATUS?
Sending Status
Packet Size: 9
Reading Packet
Contents:
LIGHT_OFF
Light Off
Packet Size: 7
Reading Packet
Contents:
STATUS?
Sending Status
