SPIFFS.format() always fails with WDT Reset
Posted: Mon Oct 31, 2016 5:06 pm
I'm at my wits end, and ready to believe in a hardware failure of my Flash chip, but let's try here first.
I have an ESP-12F and whenever I try SPIFFS.format() or SPIFFS.begin() I get a long pause and eventually a WDT reset.
I've downloaded and run the same software in a couple of other ESP-12F boards with no problem. I can download any software that doesn't use SPIFFS to the board without any problem, it works as expected.
I've now minimised my code to the following and it still fails:
And here is the decoded stack trace:
Should I consider this module a loss, or is there anything I can try to get it behaving normally again?
#include <FS.h>
Serial.println("Will format flash");
bool ok = SPIFFS.format();
Serial.println("Done!");
if (ok) {
Serial.println("And with success");
} else {
Serial.println("But it failed:-(");
0x40105600: spi_flash_write at ?? line ?
0x40206b98: __yield at /Users/jack/Library/Arduino15/packages/esp8266/hardware/esp8266/2.3.0/cores/esp8266/core_esp8266_main.cpp line 56
0x40207a96: EspClass::flashWrite(unsigned int, unsigned int*, unsigned int) at /Users/jack/Library/Arduino15/packages/esp8266/hardware/esp8266/2.3.0/cores/esp8266/Esp.cpp line 512
0x4020790f: spiffs_hal_write(unsigned int, unsigned int, unsigned char*) at /Users/jack/Library/Arduino15/packages/esp8266/hardware/esp8266/2.3.0/cores/esp8266/spiffs_hal.cpp line 116
0x4010118a: ppEnqueueRxq at ?? line ?
0x40100f57: ppProcessTxQ at ?? line ?
0x401015f6: pp_post at ?? line ?
0x401048b8: lmacTxFrame at ?? line ?
0x40103ac7: lmacRecycleMPDU at ?? line ?
0x40103f2a: lmacRecycleMPDU at ?? line ?
0x40103a0e: lmacProcessTxSuccess at ?? line ?
0x4010383d: lmacProcessTXStartData at ?? line ?
0x40102973: wDev_ProcessFiq at ?? line ?
0x401050e5: ets_timer_disarm at ?? line ?
0x40205435: spiffs_phys_rd at /Users/jack/Library/Arduino15/packages/esp8266/hardware/esp8266/2.3.0/cores/esp8266/spiffs/spiffs_cache.c line 140
0x40203384: spiffs_obj_lu_scan at /Users/jack/Library/Arduino15/packages/esp8266/hardware/esp8266/2.3.0/cores/esp8266/spiffs/spiffs_nucleus.c line 941
0x4020557c: spiffs_phys_wr at /Users/jack/Library/Arduino15/packages/esp8266/hardware/esp8266/2.3.0/cores/esp8266/spiffs/spiffs_cache.c line 204
0x40207a5c: EspClass::flashEraseSector(unsigned int) at /Users/jack/Library/Arduino15/packages/esp8266/hardware/esp8266/2.3.0/cores/esp8266/Esp.cpp line 508
0x40206bd8: optimistic_yield at /Users/jack/Library/Arduino15/packages/esp8266/hardware/esp8266/2.3.0/cores/esp8266/core_esp8266_main.cpp line 56
0x4020328c: spiffs_erase_block at /Users/jack/Library/Arduino15/packages/esp8266/hardware/esp8266/2.3.0/cores/esp8266/spiffs/spiffs_nucleus.c line 941
0x4020789c: spiffs_hal_write(unsigned int, unsigned int, unsigned char*) at /Users/jack/Library/Arduino15/packages/esp8266/hardware/esp8266/2.3.0/cores/esp8266/spiffs_hal.cpp line 102
0x402079e0: spiffs_hal_erase(unsigned int, unsigned int) at /Users/jack/Library/Arduino15/packages/esp8266/hardware/esp8266/2.3.0/cores/esp8266/spiffs_hal.cpp line 168
0x40201df4: SPIFFS_format at /Users/jack/Library/Arduino15/packages/esp8266/hardware/esp8266/2.3.0/cores/esp8266/spiffs/spiffs_hydrogen.c line 980
0x402076f2: SPIFFSImpl::format() at /Users/jack/Library/Arduino15/packages/esp8266/hardware/esp8266/2.3.0/cores/esp8266/spiffs_api.h line 158
0x40207c25: fs::FS::format() at /Users/jack/Library/Arduino15/packages/esp8266/hardware/esp8266/2.3.0/cores/esp8266/FS.cpp line 251
0x40206584: setup at /Users/jack/Documents/Arduino/sketch_oct31a/sketch_oct31a.ino line 8
0x40206b64: loop_wrapper at /Users/jack/Library/Arduino15/packages/esp8266/hardware/esp8266/2.3.0/cores/esp8266/core_esp8266_main.cpp line 56
0x40100114: cont_norm at /Users/jack/Library/Arduino15/packages/esp8266/hardware/esp8266/2.3.0/cores/esp8266/cont.S line 109
