I want to introduce a project I have been working on for quite some time: I call them Lambda Nodes.
Lambda Nodes are small wireless sensors based on NRF24L01 transceiver modules with the goal to be small, low price easy to use and open source. To my knowledge there is no such thing yet: either the sensors are expensive, bulky or closed source.
I designed the Lambda Nodes to be very easy to install. The software automatically detects the nodes, configures them and either saves the data on an SD card or streams it to a server like thingspeak, a MQTT broker, plot.ly or wherever you want. No more hustle with I2C libraries, wrong readings and messy wires.
Using the custom designed ESP8266 base station called the Alpha node you can easily configure the nodes with the built in web page and of course customize the code to your needs.
This is what it looks like:
And this is one of the sensor nodes (based on a BME280):
The project is in an advanced state, all the hardware is working and the software is almost ready to be released.
I recently made a simple introduction website on wordpress. There are more photos and a more detailed description of the project: Lambda Nodes website
Also I recorded a video showing the setup I made for the Zürich Maker Faire and the live data streaming capability:
Demo Video
Here are some specs of the advanced prototypes:
- Radio frequency: 2.4GHz
Transmission range: up to 70m
Battery: CR2032
Battery life: up to 3 years
Theta Node (Temperature)
- Size: 43x22x9mm (LxWxH)
Accuracy: ±0.5°C
Resolution: 0.02°C
Sensor: precision NTC
Range: -20°C to 80°C (up to 250°C with external NTC)
Epsilon Node (Soil Moisture probe)
- Size: 100x22x9mm (LxWxH)
Resolution: 0.1% (0% is dry, 100% is fully wet)
Sensor: capacitive probe
Kappa Node (environment sensor)
Sensor: BME280
Measures temperature, humidity and pressure
Alpha Node (receiver station)
- Size: 50x50x12mm (LxWxH)
Uses ESP8266 for WiFi
SD card for local data-logging
Contains configuration web-page
Please let me know if you would like to me to have them manufactured for you, the minimum order quantity is 100pcs, the price will be around 20$ at this quantity, I already got a rough quote from Seeedstudio.
Sorry the project is not yet open source, it will be as soon as I get them manufactured.
