I am running Arduino IDE 1.6.5 with version 2.2.0 of the esp8266 module. I am using a nodeMCU 1.0. Everything seemed to be working fine until I tried to connect to my AP.
The AP accepts 802.11b and g connections. WEP is off, WPA is on. The nodeMCU finds the AP when it scans using the Arduino example WiFiScan sketch (to which I added the encryption type at the end of the line). See attached pdf for AP 1UXG7.
But it will not connect with this code:
const char* ssid = "1UXG7";
const char* password = "HappyBirthday";
delay(100);
Serial.setDebugOutput(true);
WiFi.begin(ssid, password);
String s = WiFi.macAddress();
Serial.print("Mac Address: ");
Serial.println(s);
Serial.print(WiFi.SSID());
delay(2500);
Serial.print(".");
Serial.println(WiFi.status());
WiFi.printDiag(Serial);
Serial.println("");
}I have attached the diagnostics output in an attachment. Can anyone tell me what is wrong? Note that "HappyBirthday" is not the real password, but the output appears the same even with the correct one.
Thanks.
