Serial.begin(74880);
Serial.println("Booting\n");
Serial.printf("Reset reason: %s\n",ESP.getResetReason().c_str());
Serial.printf("Vcc: %d\n", ESP.getVcc());
Serial.printf("ESP8266 ID: %08X\n", ESP.getChipId());
Serial.printf("Flash ID: %08X\n", ESP.getFlashChipId());
Serial.printf("Flash size: %u\n\n", ESP.getFlashChipRealSize());
Serial.printf("\nConnecting");
WiFi.mode(WIFI_STA);
WiFi.config(wifi_ip, wifi_gateway, wifi_subnet);
WiFi.begin(wifi_ssid, wifi_password, wifi_channel, wifi_bssid);
delay(100);
Serial.printf(".");
Serial.printf("\n");
Serial.printf("\nSSID: %s\n", WiFi.SSID().c_str());
Serial.printf("IP: %s\n",WiFi.localIP().toString().c_str());
Serial.printf("Mac-addr: %s\n", WiFi.BSSIDstr().c_str());
Serial.printf("RSSI: %d dBm\n", WiFi.RSSI());
This produces this output: (Notice the gibberish output from the first Serial.printf lines)
ets Jan 8 2013,rst cause:2, boot mode:(3,0)
tail 8
chksum 0x2d
csum 0x2d
v09f0c112
~ld
½½Ñ¥¹�)jR$Uk•Ñ�’•…ͽ¹é*…ѕɹ…±�šåÍÑ•µ)²��éšÂ‚ªRT5…’²²JE¥‚‚‚*Â2•RdÅ+kRŠ”‚‚Š¢¢‚*RdÅ+kÒW-¯Y'HHL˜š8576
Connecting....
SSID: heeke
IP: 192.168.0.51
Mac-addr: 10:C3:7B:44:5C:BA
RSSI: -60 dBm
So I added a delay after Serial.begin, Everything else the same.
delay(1000);
AndI get this output.
tail 8
chksum 0x2d
csum 0x2d
v09f0c112
~ld
ÿBooting
Reset reason: External System
Vcc: 3797
ESP8266 ID: 000E08F9
Flash ID: 001440E0
Flash size: 1048576
Connecting....................................................................................Only problem, the wifi never connects. And yes, this is repeatable over and over again with just adding or deleting that 1 second delay.
What is really happening here?
Why do I get gibberish output in the first case?
And why won't the wifi connect if I add a delay?
