By frischevollmilch
#58441 Hello, I am trying to save my wifi credentials of my ESP8266 in EEPROM with the following code:
Code: Select all#include <EEPROM.h>
struct WifiCredentials
  String ssid;
  String passphrase;
bool saveCredentials(String ssid, String passphrase)
  uint16_t ssid_address = 0;
  for(int i = ssid_address; i < ssid_address + 32; i++)
    EEPROM.write(i, ssid[i]);
  uint16_t passphrase_address = 32;
  for(int i = passphrase_address; i < passphrase_address + 32; i++)
    EEPROM.write(i, passphrase[i]);
  EEPROM.commit();
  return true;
WifiCredentials loadCredentials()
  String ssid;
  String passphrase;
    ssid += char(EEPROM.read(i));
    passphrase += char(EEPROM.read(i));
  return WifiCredentials { ssid, passphrase };
  Serial.println("");
  EEPROM.begin(512);
  saveCredentials("abc", "123");
  WifiCredentials cred = loadCredentials();
  Serial.println(cred.ssid);
  Serial.println(cred.passphrase);
Now I am writing the example credentials into EEPROM and then read them again. I would expect the output to be:
Code: Select allabc
123
but instead it is:
Code: Select allabc
I checked the code a thousand times but couldn't find my mistake. The only thing I could imagine would be my ESP8266 being broken at this point but at the other hand it's probably just a stupid mistake.
Can you guys help me out? Thanks!
By eduperez
#58459 Problem is in this loop inside "saveCredentials":
Code: Select all  uint16_t passphrase_address = 32;
Here, "i" starts at 32 and goes up to 63, thus you cannot use it at "passphrase[i]"; I would try this instead:
  for(int i = 0; i < 32; i++)
    EEPROM.write(i + passphrase_address, passphrase[i]);
