attachInterrupt(0, zero_cross, FALLING);void zero_cross() {
zero_cross_trig = true;}void loop() {
while (!zero_cross_trig);
// your interrupt code here
zero_cross_trig = false;Explore... Chat... Share...
zero_cross_trig = false;It takes about 20-25 seconds for home assistant c[…]
