I'm using this library and example sketch: https://github.com/adafruit/Adafruit_BME280_Library
I'm not able to recieve data. The error message:
Could not find a valid BME280 sensor, check wiring!appeares.
I try to connect by SCL and SDA.
Where do I need to connect the SCL and SDA connections? On what pins?
Or is there somewhere an example sketch to test?
I'm used to use the old BMP180. In that sketch I can define the SCL and SDA pins
by using:
#define SDAPIN 04
#define SCLPIN 05
Wire.begin(SDAPIN, SCLPIN); //sda, scl
Wire.begin();The code dislayed by theBME280 connected to NodeMCU on pins GPIO4 and GPIO5:
ctx: cont
sp: 3ffe9d50 end: 3ffe9f20 offset: 01b0
>>>stack>>>
3ffe9f00: 00000000 00000000 3ffe9f44 40201133
3ffe9f10: 00000000 00000000 3ffe8f00 40100118
<<<stack<<<
load 0x4010f000, len 1264, room 16
tail 0
chksum 0x42
csum 0x42
~ld
BME280 test
Could not find a valid BME280 sensor, check wiring!chksum is 0x42 (no connection found)
It should be 0x77 or 0x76
