receiving a string from nextion display
PostPosted: Thu Jan 26, 2017 7:51 pm
by BlueEther
Hi all
What's the best way to receive a string (softserial) from a nextion display and then deciding what to do?
At the moment I'm using if - else if - else if....
Code: Select allvoid loop() {
  //String message = myNextion.listen(); //check for message
  parseNexMsg(myNextion.listen());
  if(nexChange){
//    Serial.println(int(nexPage));
//    Serial.println(int(nexButton));
    updateNexData();
    updateNexPage(nexPage, nexButton);
    nexChange = FALSE;
  //Start main temp log
  if (USELED) digitalWrite(LEDPin, HIGH);
  if(millis() - mills > 10000){
  mills= millis();
// Main code...
Code: Select allvoid parseNexMsg(String msg){
  if (msg == "65 0 1 0 ff ff ff") {       //Main page button pressed
    nexPage = 1;
    nexButton = 3;
    nexChange = TRUE;
    ckAVgTemp(hourAvg[0][minute()]);
    ckAVgTemp(hourAvg[1][minute()]);
  }else if (msg == "65 0 3 0 ff ff ff") { //Graph page button pressed
    nexPage = 3;
    nexButton = 0;
    nexChange = TRUE;
  }else if (msg == "65 1 b 1 ff ff ff") { //humidity button on main
    nexPage = 1;
    nexButton = 2;
    nexChange = TRUE;
  }else if (msg == "65 1 c 1 ff ff ff") { //top temp button on main
    nexPage = 1;
    nexButton = 3;
    nexChange = TRUE;
  }else if (msg == "65 1 e 1 ff ff ff") { //bottom button on main
    nexPage = 1;
    nexButton = 5;
    nexChange = TRUE;
  }else if (msg == "65 1 15 0 ff ff ff") {  //save button on main
    nexPage = 1;
    nexButton = 7;
    nexChange = TRUE;
  }else if (msg == "65 3 2 0 ff ff ff" || msg == "65 1 14 0 ff ff ff" || msg == "65 2 1 0 ff ff ff") {  //menu button
    nexPage = 0;
    nexButton = 0;
    nexChange = false;
  }else if (msg == "65 3 4 1 ff ff ff") {  //top temp button on gauge
    nexPage = 3;
    nexButton = 0;
    nexChange = TRUE;
  }else if (msg == "65 3 5 1 ff ff ff") {  //top temp button on gauge
    nexPage = 3;
    nexButton = 1;
    nexChange = TRUE;
  }else if (msg == "65 3 6 1 ff ff ff") {  //top temp button on gauge
    nexPage = 3;
    nexButton = 2;
    nexChange = TRUE;
What's the best way to this sort of thing?
