Putting ESP8266 in bootloader mode
PostPosted: Tue Jan 31, 2017 8:25 am
by seanspotatobusiness
I'm a noob trying to make a small improvement to documentation about the process of applying FFS to the ESP8266 and I need help making it applicable to all the ESP8266 variants. I tried to present the change at this GitHub thread
I've been using an Adafruit HUZZAH ESP8266 which has to be manually put into bootloader mode before uploading instructions via USB to TTL cable. Apparently that isn't necessary on some ESP8266 modules? Apparently some modules will go into bootloader mode automatically? Does it make a difference whether you're using NodeMCU versus Arduino IDE? I've never used NodeMCU/Lua.
Incidentally, can NodeMCU/Lua have the FFS or is that just for Arduino?
Re: Putting ESP8266 in bootloader mode
PostPosted: Tue Jan 31, 2017 6:44 pm
by gdsports
The following boards (and many more) do not require any button pushing to enter bootload mode: Adafruit Feather ESP8266, NodeMCU devkit 1.0, Wemos d1 mini. All have built-in USB to serial chips which use DTR (I think) to ground GPIO0 and reset the ESP. The Arduino IDE controls DTR so it can automatically put the ESP8266 into bootload mode.
Boards such as the original ESP8266 Huzzah does not have a USB serial chip therefore no DTR so buttons connected to reset and GPIO0 must be used. The IDE cannot put the Huzzah into bootload mode.
PostPosted: Wed Feb 01, 2017 9:10 am
gdsports wrote:The following boards (and many more) do not require any button pushing to enter bootload mode: Adafruit Feather ESP8266, NodeMCU devkit 1.0, Wemos d1 mini. All have built-in USB to serial chips which use DTR (I think) to ground GPIO0 and reset the ESP. The Arduino IDE controls DTR so it can automatically put the ESP8266 into bootload mode.
Thanks a lot for all this clear information.
