How to choose WiFiClient vs. WiFiClientSecure at runtime?
PostPosted: Tue Mar 07, 2017 11:49 pm
by Humancell
I'm working on some code that is POSTing JSON to a user defined endpoint. I'm parsing the URI provided by the user, and can detect the scheme being specified: http vs. https
Now when I am wanting to POST the data, I am currently using WiFiClient ... but I want to now check the scheme (http vs. https) and then use the appropriate client.
My goal is that somehow at the beginning of my function I can chose the "client" to use by doing something like this:
Code: Select all    // http or https?
    if(!strcmp(endpointScheme, "http")) {
      WiFiClient client;
      #ifdef DEBUG
      Serial.println(F("Using HTTP://"));
      #endif
    } else {
      // Use WiFiClientSecure class to create TCP connections
      WiFiClientSecure client;
      #ifdef DEBUG
      Serial.println(F("Using HTTPS://"));
      #endif
If I could do this then I can simply use the "client" reference in the rest of my code, independent of it being a secure or non-secure connection. But this doesn't work. :-)
How can I do this?
Is there a way that I can define both in advance and then assign "client" to the one that I want? If so ... then what data type is "client"?
Or can I do this?
    WiFiClient httpClient;
    WiFiClientSecure httpsClient;
      client = httpClient;
      #ifdef DEBUG
      #endif
    } else {
      client = httpsClient;
      #ifdef DEBUG
      #endif
Is there some way to do this?
