#include <Wire.h>
//#include <SPI.h>
#include <PubSubClient.h>
//#include <string.h>
//#include <stdio.h>
// Settings
const char* ssid = "Tomato Express"; // SSID
const char* password = "notyournetwork"; // Wifi PWD
const char* server = "10.0.0.10"; // IP address of your MQTT server
//const char* outTopic = "test/"; // Topic to publish to
const char* inTopic = "inTopic"; // Topic to subscribe to
// Wifi MAC address
byte mac[]= { 0xDE, 0xED, 0xBA, 0xFE, 0xFE, 0xED };
// I2C address of the MPU-6050 & 0x68 or 0x69 if AD0 is pulled HIGH
const int MPU = 0x68; // MPU6050 #1
const int MPU2 = 0x69; // MPU6050 #2
int16_t AcX, AcY, AcZ, GyX, GyY, GyZ; // MPU6050 #1
int16_t AcX2, AcY2, AcZ2, GyX2, GyY2, GyZ2; // MPU6050 #2
float gForceX, gForceY, gForceZ, rotX, rotY, rotZ; // MPU6050 #1
float gForceX2, gForceY2, gForceZ2, rotX2, rotY2, rotZ2; // MPU6050 #2
WiFiClient espClient;
IPAddress ip;
PubSubClient mqttClient(espClient);
void setup(){
Serial.begin(9600);
// MPU6050 #1
Wire.begin(0,2); // GPIO0, GPIO2
Wire.beginTransmission(MPU);
Wire.write(0x6B); // PWR_MGMT_1 register
Wire.write(0); // Sset to zero (wakes up the MPU6050)
Wire.endTransmission(true);
// MPU6050 #2
// Wire.begin(0,2);
Wire.beginTransmission(MPU2);
Wire.write(0); // Set to zero (wakes up the MPU6050)
mqttClient.setServer(server, 1883); // Set MQTT server
mqttClient.setCallback(callback); // Set subscribe
Serial.println(ip); // Print the IP?
Serial.println(server); // Print the server?
//delay(10);
void setup_wifi() {
delay(10);
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
void callback(char* topic, byte* payload, unsigned int length) {
// Subscribe functions, print the incoming message
Serial.print("Message arrived [");
Serial.print(topic);
Serial.print("] ");
for (int i = 0; i < length; i++) {
Serial.print((char)payload[i]);
if ((char)payload[0] == '1') {
// digitalWrite(led, LOW); // Turn the LED on (Note that LOW is the voltage level
// do stuff
dataAcc();
dataGy();
} else {
// digitalWrite(led, HIGH); // Turn the LED off by making the voltage HIGH
// do more stuff
Serial.print("Not initiated");
void dataReceiver(){
Wire.write(0x3B); // starting with register 0x3B (ACCEL_XOUT_H)
Wire.endTransmission(false);
Wire.requestFrom(MPU,14,true); // request a total of 14 registers
AcX = Wire.read()<<8|Wire.read(); // 0x3B (ACCEL_XOUT_H) & 0x3C (ACCEL_XOUT_L)
AcY = Wire.read()<<8|Wire.read(); // 0x3D (ACCEL_YOUT_H) & 0x3E (ACCEL_YOUT_L)
AcZ = Wire.read()<<8|Wire.read(); // 0x3F (ACCEL_ZOUT_H) & 0x40 (ACCEL_ZOUT_L)
GyX = Wire.read()<<8|Wire.read(); // 0x43 (GYRO_XOUT_H) & 0x44 (GYRO_XOUT_L)
GyY = Wire.read()<<8|Wire.read(); // 0x45 (GYRO_YOUT_H) & 0x46 (GYRO_YOUT_L)
GyZ = Wire.read()<<8|Wire.read(); // 0x47 (GYRO_ZOUT_H) & 0x48 (GYRO_ZOUT_L)
// processData();
Wire.requestFrom(MPU2,14,true); // request a total of 14 registers
AcX2 = Wire.read()<<8|Wire.read(); // 0x3B (ACCEL_XOUT_H) & 0x3C (ACCEL_XOUT_L)
AcY2 = Wire.read()<<8|Wire.read(); // 0x3D (ACCEL_YOUT_H) & 0x3E (ACCEL_YOUT_L)
AcZ2 = Wire.read()<<8|Wire.read(); // 0x3F (ACCEL_ZOUT_H) & 0x40 (ACCEL_ZOUT_L)
GyX2 = Wire.read()<<8|Wire.read(); // 0x43 (GYRO_XOUT_H) & 0x44 (GYRO_XOUT_L)
GyY2 = Wire.read()<<8|Wire.read(); // 0x45 (GYRO_YOUT_H) & 0x46 (GYRO_YOUT_L)
GyZ2 = Wire.read()<<8|Wire.read(); // 0x47 (GYRO_ZOUT_H) & 0x48 (GYRO_ZOUT_L)
processData();
void processData(){
gForceX = AcX / 16384.0;
gForceY = AcY / 16384.0;
gForceZ = AcZ / 16384.0;
rotX = GyX / 131.0;
rotY = GyY / 131.0;
rotZ = GyZ / 131.0;
gForceX2 = AcX2 / 16384.0;
gForceY2 = AcY2 / 16384.0;
gForceZ2 = AcZ2 / 16384.0;
rotX2 = GyX2 / 131.0;
rotY2 = GyY2 / 131.0;
rotZ2 = GyZ2 / 131.0;
void debugFunction(int16_t AcX, int16_t AcY, int16_t AcZ, int16_t GyX, int16_t GyY, int16_t GyZ){
// Print the MPU values to the serial monitor
Serial.print("Accelerometer: ");
Serial.print("X="); Serial.print(gForceX);
Serial.print("|Y="); Serial.print(gForceY);
Serial.print("|Z="); Serial.println(gForceZ);
Serial.print("Gyroscope:");
Serial.print("X="); Serial.print(rotX);
Serial.print("|Y="); Serial.print(rotY);
Serial.print("|Z="); Serial.println(rotZ);
void debugFunction2(int16_t AcX2, int16_t AcY2, int16_t AcZ2, int16_t GyX2, int16_t GyY2, int16_t GyZ2){
// Print the MPU2 values to the serial monitor
Serial.print("Accelerometer2: ");
Serial.print("X2="); Serial.print(gForceX2);
Serial.print("|Y2="); Serial.print(gForceY2);
Serial.print("|Z2="); Serial.println(gForceZ2);
Serial.print("Gyroscope2:");
Serial.print("X2="); Serial.print(rotX2);
Serial.print("|Y2="); Serial.print(rotY2);
Serial.print("|Z2="); Serial.println(rotZ2);
char* init(float val){
char buff[100];
for (int i = 0; i < 100; i++) {
dtostrf(val, 4, 2, buff); //4 is mininum width, 6 is precision
return buff;
void dataAcc(){
char mpu6050X[100]= "";
strcat(mpu6050X,init(gForceX));
char mpu6050Y[100]= "";
strcat(mpu6050Y,init(gForceY));
char mpu6050Z[100]= "";
strcat(mpu6050Z,init(gForceZ));
// accelerometer - "topic, mpu6050"
mqttClient.publish("AcX/", mpu6050X);
mqttClient.publish("AcY/", mpu6050Y);
mqttClient.publish("AcZ/", mpu6050Z);
char mpu6050X2[100]= "";
strcat(mpu6050X2,init(gForceX2));
char mpu6050Y2[100]= "";
strcat(mpu6050Y2,init(gForceY2));
char mpu6050Z2[100]= "";
strcat(mpu6050Z2,init(gForceZ2));
mqttClient.publish("AcX2/", mpu6050X2);
mqttClient.publish("AcY2/", mpu6050Y2);
mqttClient.publish("AcZ2/", mpu6050Z2);
// mqttClient.publish(outTopic, "text to send via mqtt");
void dataGy(){
strcat(mpu6050X,init(rotX));
strcat(mpu6050Y,init(rotY));
strcat(mpu6050Z,init(rotZ));
// gyroscope - "topic, mpu6050"
mqttClient.publish("GyX/", mpu6050X);
mqttClient.publish("GyY/", mpu6050Y);
mqttClient.publish("GyZ/", mpu6050Z);
strcat(mpu6050X2,init(rotX2));
strcat(mpu6050Y2,init(rotY2));
strcat(mpu6050Z2,init(rotZ2));
mqttClient.publish("GyX2/", mpu6050X2);
mqttClient.publish("GyY2/", mpu6050Y2);
mqttClient.publish("GyZ2/", mpu6050Z2);
void reconnect() {
// Loop until we're reconnected
while (!mqttClient.connected()) {
Serial.print("Attempting MQTT connection...");
// Attempt to connect
if (mqttClient.connect("arduinoClient")){
Serial.println("connected");
// subscribe to topic
mqttClient.subscribe(inTopic);
} else {
Serial.print("failed, rc=");
Serial.print(mqttClient.state());
Serial.println(" try again in 5 seconds");
// Wait 5 seconds before retrying
delay(1000);
void loop(){
dataReceiver();
debugFunction(AcX,AcY,AcZ,GyX,GyY,GyZ);
debugFunction2(AcX2,AcY2,AcZ2,GyX2,GyY2,GyZ2);
if (!mqttClient.connected()) {
reconnect();
mqttClient.loop();
// dataAcc();
// dataGy();
delay(3000);
}Moderator: igrr
//espclient.subscribe(topic); //// your specific topic
espclient.subscribe("#"); ////// we will receive all messages
///const char* user_name = "";
///const char* password = "";
///const char* clientID = ""; // client ID
String topic="IoT";
////WiFiClient wclient; /// instantiate the wifi
////PubSubClient client(wclient, serverURI, port); /// instantiate the MQTT pubsub
void callback(const MQTT::Publish& pub)
{ // handle incoming message
///// Pub.payload_string() // has received data from broker
//// client.publish(topic, String( message goes here)); //// send response to message from broker if you want to
void setup()
///// client.set_callback(callback); ///sets up callback
//// WiFi.begin(ssid, pass); //// sets up wifi connection
////client.connect(MQTT::Connect(String("who we are to the broker")).set_auth(user_name, password)
If (client.connected())
/////client.publish(topic, String(message string)); //// send message to broker if needed at set up
void loop()
////// client.loop(); ///// keep in contact with the broker
