- Sun Mar 26, 2017 2:43 pm
#64248
I found some answers to my questions. Maybe it will be helpful to others.
1.) LetsEncrypt is a tricky example as the certificate is cross-signed be another CA. axTLS seems to verfiy against the highest depth-level in the chain an therefore the recommended intermediate from letsencrypt cannot be used for matching. You have to take the certificate from
https://www.identrust.com/certificates/trustid/root-download-x3.html.
2.) The idea for the way I included the certificate was born by the way it is done for Superhouse Open-RTOS and also I found a similar example in arduino-esp32. Both are using mbedtls. This seems to be wrong for the actual ESP8266 Arduino, which is using axTLS. Meanwhile I found the following solution to prepare the above mentioned certificate:
Code: Select allopenssl enc -d -a -in dst-root-ca-x3.crt > dst-root-ca-x3.bin.crt
xxd -i dst-root-ca-x3.bin.crt This results in the following code which can be used in the sketch
Code: Select allunsigned char dst_root_ca_x3_bin_crt[] = {
0x30, 0x82, 0x03, 0x4a, 0x30, 0x82, 0x02, 0x32, 0xa0, 0x03, 0x02, 0x01,
0x02, 0x02, 0x10, 0x44, 0xaf, 0xb0, 0x80, 0xd6, 0xa3, 0x27, 0xba, 0x89,
0x30, 0x39, 0x86, 0x2e, 0xf8, 0x40, 0x6b, 0x30, 0x0d, 0x06, 0x09, 0x2a,
0x86, 0x48, 0x86, 0xf7, 0x0d, 0x01, 0x01, 0x05, 0x05, 0x00, 0x30, 0x3f,
0x31, 0x24, 0x30, 0x22, 0x06, 0x03, 0x55, 0x04, 0x0a, 0x13, 0x1b, 0x44,
0x69, 0x67, 0x69, 0x74, 0x61, 0x6c, 0x20, 0x53, 0x69, 0x67, 0x6e, 0x61,
0x74, 0x75, 0x72, 0x65, 0x20, 0x54, 0x72, 0x75, 0x73, 0x74, 0x20, 0x43,
0x6f, 0x2e, 0x31, 0x17, 0x30, 0x15, 0x06, 0x03, 0x55, 0x04, 0x03, 0x13,
0x0e, 0x44, 0x53, 0x54, 0x20, 0x52, 0x6f, 0x6f, 0x74, 0x20, 0x43, 0x41,
0x20, 0x58, 0x33, 0x30, 0x1e, 0x17, 0x0d, 0x30, 0x30, 0x30, 0x39, 0x33,
0x30, 0x32, 0x31, 0x31, 0x32, 0x31, 0x39, 0x5a, 0x17, 0x0d, 0x32, 0x31,
0x30, 0x39, 0x33, 0x30, 0x31, 0x34, 0x30, 0x31, 0x31, 0x35, 0x5a, 0x30,
0x3f, 0x31, 0x24, 0x30, 0x22, 0x06, 0x03, 0x55, 0x04, 0x0a, 0x13, 0x1b,
0x44, 0x69, 0x67, 0x69, 0x74, 0x61, 0x6c, 0x20, 0x53, 0x69, 0x67, 0x6e,
0x61, 0x74, 0x75, 0x72, 0x65, 0x20, 0x54, 0x72, 0x75, 0x73, 0x74, 0x20,
0x43, 0x6f, 0x2e, 0x31, 0x17, 0x30, 0x15, 0x06, 0x03, 0x55, 0x04, 0x03,
0x13, 0x0e, 0x44, 0x53, 0x54, 0x20, 0x52, 0x6f, 0x6f, 0x74, 0x20, 0x43,
0x41, 0x20, 0x58, 0x33, 0x30, 0x82, 0x01, 0x22, 0x30, 0x0d, 0x06, 0x09,
0x2a, 0x86, 0x48, 0x86, 0xf7, 0x0d, 0x01, 0x01, 0x01, 0x05, 0x00, 0x03,
0x82, 0x01, 0x0f, 0x00, 0x30, 0x82, 0x01, 0x0a, 0x02, 0x82, 0x01, 0x01,
0x00, 0xdf, 0xaf, 0xe9, 0x97, 0x50, 0x08, 0x83, 0x57, 0xb4, 0xcc, 0x62,
0x65, 0xf6, 0x90, 0x82, 0xec, 0xc7, 0xd3, 0x2c, 0x6b, 0x30, 0xca, 0x5b,
0xec, 0xd9, 0xc3, 0x7d, 0xc7, 0x40, 0xc1, 0x18, 0x14, 0x8b, 0xe0, 0xe8,
0x33, 0x76, 0x49, 0x2a, 0xe3, 0x3f, 0x21, 0x49, 0x93, 0xac, 0x4e, 0x0e,
0xaf, 0x3e, 0x48, 0xcb, 0x65, 0xee, 0xfc, 0xd3, 0x21, 0x0f, 0x65, 0xd2,
0x2a, 0xd9, 0x32, 0x8f, 0x8c, 0xe5, 0xf7, 0x77, 0xb0, 0x12, 0x7b, 0xb5,
0x95, 0xc0, 0x89, 0xa3, 0xa9, 0xba, 0xed, 0x73, 0x2e, 0x7a, 0x0c, 0x06,
0x32, 0x83, 0xa2, 0x7e, 0x8a, 0x14, 0x30, 0xcd, 0x11, 0xa0, 0xe1, 0x2a,
0x38, 0xb9, 0x79, 0x0a, 0x31, 0xfd, 0x50, 0xbd, 0x80, 0x65, 0xdf, 0xb7,
0x51, 0x63, 0x83, 0xc8, 0xe2, 0x88, 0x61, 0xea, 0x4b, 0x61, 0x81, 0xec,
0x52, 0x6b, 0xb9, 0xa2, 0xe2, 0x4b, 0x1a, 0x28, 0x9f, 0x48, 0xa3, 0x9e,
0x0c, 0xda, 0x09, 0x8e, 0x3e, 0x17, 0x2e, 0x1e, 0xdd, 0x20, 0xdf, 0x5b,
0xc6, 0x2a, 0x8a, 0xab, 0x2e, 0xbd, 0x70, 0xad, 0xc5, 0x0b, 0x1a, 0x25,
0x90, 0x74, 0x72, 0xc5, 0x7b, 0x6a, 0xab, 0x34, 0xd6, 0x30, 0x89, 0xff,
0xe5, 0x68, 0x13, 0x7b, 0x54, 0x0b, 0xc8, 0xd6, 0xae, 0xec, 0x5a, 0x9c,
0x92, 0x1e, 0x3d, 0x64, 0xb3, 0x8c, 0xc6, 0xdf, 0xbf, 0xc9, 0x41, 0x70,
0xec, 0x16, 0x72, 0xd5, 0x26, 0xec, 0x38, 0x55, 0x39, 0x43, 0xd0, 0xfc,
0xfd, 0x18, 0x5c, 0x40, 0xf1, 0x97, 0xeb, 0xd5, 0x9a, 0x9b, 0x8d, 0x1d,
0xba, 0xda, 0x25, 0xb9, 0xc6, 0xd8, 0xdf, 0xc1, 0x15, 0x02, 0x3a, 0xab,
0xda, 0x6e, 0xf1, 0x3e, 0x2e, 0xf5, 0x5c, 0x08, 0x9c, 0x3c, 0xd6, 0x83,
0x69, 0xe4, 0x10, 0x9b, 0x19, 0x2a, 0xb6, 0x29, 0x57, 0xe3, 0xe5, 0x3d,
0x9b, 0x9f, 0xf0, 0x02, 0x5d, 0x02, 0x03, 0x01, 0x00, 0x01, 0xa3, 0x42,
0x30, 0x40, 0x30, 0x0f, 0x06, 0x03, 0x55, 0x1d, 0x13, 0x01, 0x01, 0xff,
0x04, 0x05, 0x30, 0x03, 0x01, 0x01, 0xff, 0x30, 0x0e, 0x06, 0x03, 0x55,
0x1d, 0x0f, 0x01, 0x01, 0xff, 0x04, 0x04, 0x03, 0x02, 0x01, 0x06, 0x30,
0x1d, 0x06, 0x03, 0x55, 0x1d, 0x0e, 0x04, 0x16, 0x04, 0x14, 0xc4, 0xa7,
0xb1, 0xa4, 0x7b, 0x2c, 0x71, 0xfa, 0xdb, 0xe1, 0x4b, 0x90, 0x75, 0xff,
0xc4, 0x15, 0x60, 0x85, 0x89, 0x10, 0x30, 0x0d, 0x06, 0x09, 0x2a, 0x86,
0x48, 0x86, 0xf7, 0x0d, 0x01, 0x01, 0x05, 0x05, 0x00, 0x03, 0x82, 0x01,
0x01, 0x00, 0xa3, 0x1a, 0x2c, 0x9b, 0x17, 0x00, 0x5c, 0xa9, 0x1e, 0xee,
0x28, 0x66, 0x37, 0x3a, 0xbf, 0x83, 0xc7, 0x3f, 0x4b, 0xc3, 0x09, 0xa0,
0x95, 0x20, 0x5d, 0xe3, 0xd9, 0x59, 0x44, 0xd2, 0x3e, 0x0d, 0x3e, 0xbd,
0x8a, 0x4b, 0xa0, 0x74, 0x1f, 0xce, 0x10, 0x82, 0x9c, 0x74, 0x1a, 0x1d,
0x7e, 0x98, 0x1a, 0xdd, 0xcb, 0x13, 0x4b, 0xb3, 0x20, 0x44, 0xe4, 0x91,
0xe9, 0xcc, 0xfc, 0x7d, 0xa5, 0xdb, 0x6a, 0xe5, 0xfe, 0xe6, 0xfd, 0xe0,
0x4e, 0xdd, 0xb7, 0x00, 0x3a, 0xb5, 0x70, 0x49, 0xaf, 0xf2, 0xe5, 0xeb,
0x02, 0xf1, 0xd1, 0x02, 0x8b, 0x19, 0xcb, 0x94, 0x3a, 0x5e, 0x48, 0xc4,
0x18, 0x1e, 0x58, 0x19, 0x5f, 0x1e, 0x02, 0x5a, 0xf0, 0x0c, 0xf1, 0xb1,
0xad, 0xa9, 0xdc, 0x59, 0x86, 0x8b, 0x6e, 0xe9, 0x91, 0xf5, 0x86, 0xca,
0xfa, 0xb9, 0x66, 0x33, 0xaa, 0x59, 0x5b, 0xce, 0xe2, 0xa7, 0x16, 0x73,
0x47, 0xcb, 0x2b, 0xcc, 0x99, 0xb0, 0x37, 0x48, 0xcf, 0xe3, 0x56, 0x4b,
0xf5, 0xcf, 0x0f, 0x0c, 0x72, 0x32, 0x87, 0xc6, 0xf0, 0x44, 0xbb, 0x53,
0x72, 0x6d, 0x43, 0xf5, 0x26, 0x48, 0x9a, 0x52, 0x67, 0xb7, 0x58, 0xab,
0xfe, 0x67, 0x76, 0x71, 0x78, 0xdb, 0x0d, 0xa2, 0x56, 0x14, 0x13, 0x39,
0x24, 0x31, 0x85, 0xa2, 0xa8, 0x02, 0x5a, 0x30, 0x47, 0xe1, 0xdd, 0x50,
0x07, 0xbc, 0x02, 0x09, 0x90, 0x00, 0xeb, 0x64, 0x63, 0x60, 0x9b, 0x16,
0xbc, 0x88, 0xc9, 0x12, 0xe6, 0xd2, 0x7d, 0x91, 0x8b, 0xf9, 0x3d, 0x32,
0x8d, 0x65, 0xb4, 0xe9, 0x7c, 0xb1, 0x57, 0x76, 0xea, 0xc5, 0xb6, 0x28,
0x39, 0xbf, 0x15, 0x65, 0x1c, 0xc8, 0xf6, 0x77, 0x96, 0x6a, 0x0a, 0x8d,
0x77, 0x0b, 0xd8, 0x91, 0x0b, 0x04, 0x8e, 0x07, 0xdb, 0x29, 0xb6, 0x0a,
0xee, 0x9d, 0x82, 0x35, 0x35, 0x10
unsigned int dst_root_ca_x3_bin_crt_len = 846; 3.) To load the certificate a created _ssl context is needed. This context seems to be only available _after_ you called <WiFiClientSecure-Instance>.connect(). If you try to load the certificate before, it will just fail silently. I found this by adding DEBUGV code to WiFiClientSecure::setCACert.
If you follow the above steps, then you'll get something like:
Code: Select alldomain name: 'my.influxdb.server'
certificate matches
which looks good so far.
I'll try to interchange the certificate by a valid self-signed the next days to see, if it fails as expected. Also I'll try to read the certificate from SPIFFS instead of putting it in the code. But for my esp01 modules I think I'll leave it in the code as I can save the whole SPIFFS stack then.
