The problem I'm having is that String content = client.readStringUntil('\n'); reads line by line and if the truck say R421 is found it turns ON the LED but then continues reading down the page and turns it OFF again.
1. Can String content = client.readStringUntil('\n'); read the entire page at once into a String and not line by line?
2. How can i loop through or add the additional trucks?
XML Sample
<tfs_active_incidents>
<update_from_db_time>2017-03-27 11:58:25</update_from_db_time>
<event>
<prime_street>DUFFERIN ST NY_HARVEY'S ,</prime_street>
<cross_streets>/</cross_streets>
<dispatch_time>2017-03-27 11:53:37</dispatch_time>
<event_num>F17027706</event_num>
<event_type>Medical - Trouble Breathing</event_type>
<alarm_lev>0</alarm_lev>
<beat>145</beat>
<units_disp>P142,</units_disp>
</event>
<event>
<prime_street>HUMBER BLVD, YK</prime_street>
<cross_streets>ALLIANCE AVE / HILLDALE RD</cross_streets>
<dispatch_time>2017-03-14 17:22:57</dispatch_time>
<event_num>F17023566</event_num>
<event_type>Alarm Highrise Residential</event_type>
<beat>421</beat>
<units_disp> R421, A421, R423, C42, LA421</units_disp>
</event>
</tfs_active_incidents>My arduino code is
const char* ssid = "*********"; //actual removed
const char* password = "******"; //actual removed
////LIVE SERVER/////
//const char* host = "www.toronto.ca";
//String url = "/fire/cadinfo/livecad.xml";
////LOCAL TEST SERVER/////
const char* host = "192.168.1.103";
String url = "/tfs.xml";
int find_text(String needle, String haystack,int from) {
int foundpos = -1;
if (haystack.length()<needle.length())
return foundpos;
for (int i = from; (i < haystack.length() - needle.length()); i++) {
if (haystack.substring(i,needle.length()+i) == needle) {
foundpos = i;
return foundpos;
return foundpos;
delay(100);
pinMode(5, OUTPUT); //WIFI Indicator
pinMode(14, OUTPUT); // First Truck
pinMode(12, OUTPUT); // Second Truck
pinMode(13, OUTPUT); // Third Truck
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.print(".");
digitalWrite(5, HIGH);
delay(250);
digitalWrite(5, LOW);
delay(250);
delay(250);
delay(250);
delay(250);
Serial.println("");
Serial.println("LED Test");
// Blink LEDS for test CODE REMOVED for now
WiFiClient client;
const int httpPort = 80;
// We now create a URI for the request
Serial.println(url);
"Host: " + host + "\r\n" +
"Connection: close\r\n\r\n");
// FIND R421
while(client.available()){
Serial.print(content);
int R421 = find_text("R421",content,0);
if (R421 == -1)
Serial.println(R421);
digitalWrite(14, LOW);
Serial.println("---------------------------------");
Serial.println("R421 On Call");
digitalWrite(14, HIGH);
delay(15000);//15sec
// delay(30000);//30sec
// delay(180000);//3min
