None respons from server->args() with WiFiManager.h
PostPosted: Tue Apr 11, 2017 7:03 am
by Steen67
I have a sketch and it starts up fine but I get no respons on server->args()
What am I doing wrong
Code: Select all#include <ESP8266WiFi.h>          //https://github.com/esp8266/Arduino
//needed for library
#include <DNSServer.h>
#include <ESP8266WebServer.h>
#include <WiFiManager.h>          //https://github.com/tzapu/WiFiManager
ESP8266WebServer server(80);
void handleWebsite();
void buildWebsite();
String webSite;
  //WiFiManager
  //Local intialization. Once its business is done, there is no need to keep it around
  WiFiManager wifiManager;
  //reset settings - for testing
  //wifiManager.resetSettings();
  //tries to connect to last known settings
  //if it does not connect it starts an access point with the specified name
  //here  "AutoConnectAP" with password "password"
  //and goes into a blocking loop awaiting configuration
  if (!wifiManager.autoConnect("AutoConnectAP", "password")) {
    Serial.println("failed to connect, we should reset as see if it connects");
    delay(3000);
    ESP.reset();
    delay(5000);
  //if you get here you have connected to the WiFi
  Serial.println("connected...yeey :)");
  Serial.println("local ip");
  server.on("/",          handleWebsite);
  server.begin();
  server.handleClient();
void buildWebsite(){
  webSite = "<!DOCTYPE HTML>\n";
  webSite += "<html><form method='get' action=''>";
  webSite += "<input type='submit' value='1_On'> <input type='submit' value='1_Off'>";
  webSite += "";
  webSite += "</form>";
  webSite += "";
  webSite += "</HTML>\n";
void handleWebsite() {
Serial.println(" Load page ");
Serial.println(server.args());
  if (server.args() > 0 ) {
   for ( uint8_t i = 0; i < server.args(); i++ ) {
     Serial.println(server.argName(i));
  buildWebsite();
  server.send(200, "text/html", webSite);
And the output when I press a button
Code: Select allload 0x4010f000, len 1264, room
*WM:
*WM: AutoConnect
*WM: Connecting as wifi client...
*WM: Using last saved values, should be faster
*WM: Connection result:
*WM: 3
*WM: IP Address:
*WM: 192.168.1.167
connected...yeey :)
local ip
192.168.1.167
 Load page
0
 Load page
0
 Load page
0
Re: None respons from server->args() with WiFiManager.h
PostPosted: Wed Apr 12, 2017 12:34 am
by Steen67
I have found the error, I used submit I should use input element
