This code used to compile fine in the past, but with the current PlatformIO install it fails.
This is the line that causes the error:
static const int8_t enc_states [] PROGMEM = {0,-1,1,0,1,0,0,-1,-1,0,0,1,0,1,-1,0}; //encoder lookup tableThis is the error I'm getting:
src\main.cpp:66:21: error: enc_states causes a section type conflict with __c
const static int8_t enc_states [] PROGMEM = {0,-1,1,0,1,0,0,-1,-1,0,0,1,0,1,-1,0}; //encoder lookup table
If I remove the const keyword it will just proceed to the next place where const and PROGMEM is used, ex.:
In file included from .piolibdeps\ESP8266_SSD1306_ID562/OLEDDisplay.h:32:0,
from .piolibdeps\ESP8266_SSD1306_ID562/SSD1306Wire.h:31,
from .piolibdeps\ESP8266_SSD1306_ID562/SSD1306.h:30,
from src\main.cpp:40:
.piolibdeps\ESP8266_SSD1306_ID562/OLEDDisplayFonts.h:851:12: error: ArialMT_Plain_24 causes a section type conflict with __c
const char ArialMT_Plain_24[] PROGMEM = {
I suspect that the installation is corrupted somehow (I've tried on two different computers, same results) but I have not idea where to look to get it fixed..
Any recommendations?
