Available on Tindie: https://www.tindie.com/products/nEXT_EVO1/universal-ac-mains-dimmer-mpdmv41/
I2C address is on 0x3c (not 0x78 like the PCB says) and you can use any good SD1306-library (for instance the one from AdaFruit).
Explore... Chat... Share...
