ESP12F with ws2812 (neopixels)
Posted: Mon Jun 12, 2017 1:17 am
Greetings,
I have run into a problem when combining the neopixel library and BasicHttpClient, But when i combine them i cant get the neopixels to work. The the http client works as expected, and the neopixels work when not combined with the BasicHttpClient
The only thing i need to have done is the color of the neopixels set based on the parsing of a webpage.
I have no real idea what is going on
I use an 74HCT08 and gate for level translation.
-lasse
ESP8266 boards 2.2.0
Arduino IDE 1.8.2
Adafruit Neopixel version 1.1.1
-lasse
Arduino IDE 1.8.2
#include <Adafruit_NeoPixel.h>
* BasicHTTPClient.ino
* Created on: 24.05.2015
#include <Arduino.h>
#include <ESP8266WiFiMulti.h>
#include <ESP8266HTTPClient.h>
#define USE_SERIAL Serial
ESP8266WiFiMulti WiFiMulti;
#define PIN 5
// How many NeoPixels are attached to the Arduino?
#define NUMPIXELS 16
Adafruit_NeoPixel pixels = Adafruit_NeoPixel(NUMPIXELS, PIN, NEO_GRB + NEO_KHZ800);
int delayval = 500; // delay for half a second
void updatepixels() {
for(int i=0;i<NUMPIXELS;i++){
// pixels.Color takes RGB values, from 0,0,0 up to 255,255,255
pixels.setPixelColor(i, pixels.Color(150,0,0)); // Moderately bright green color.
pixels.show(); // This sends the updated pixel color to the hardware.
delay(delayval); // Delay for a period of time (in milliseconds).
USE_SERIAL.begin(115200);
// USE_SERIAL.setDebugOutput(true);
USE_SERIAL.println();
for(uint8_t t = 4; t > 0; t--) {
USE_SERIAL.printf("[SETUP] WAIT %d...\n", t);
USE_SERIAL.flush();
delay(1000);
WiFiMulti.addAP("Neopixel", "ESP12f");
updatepixels();
// wait for WiFi connection
if((WiFiMulti.run() == WL_CONNECTED)) {
USE_SERIAL.println("");
USE_SERIAL.print("MAC: ");
USE_SERIAL.println(WiFi.macAddress());
USE_SERIAL.print("SSID");
USE_SERIAL.println(WiFi.SSID());
USE_SERIAL.print("IP address: ");
USE_SERIAL.println(WiFi.localIP());
HTTPClient http;
USE_SERIAL.print("[HTTP] begin...\n");
// configure traged server and url
//http.begin("https://192.168.1.12/test.html", "7a 9c f4 db 40 d3 62 5a 6e 21 bc 5c cc 66 c8 3e a1 45 59 38"); //HTTPS
http.begin("http://www.ajax.esy.es/"); //HTTP
USE_SERIAL.print("[HTTP] GET...\n");
// start connection and send HTTP header
int httpCode = http.GET();
// httpCode will be negative on error
if(httpCode > 0) {
// HTTP header has been send and Server response header has been handled
USE_SERIAL.printf("[HTTP] GET... code: %d\n", httpCode);
// file found at server
if(httpCode == HTTP_CODE_OK) {
String payload = http.getString();
USE_SERIAL.println(payload);
} else {
USE_SERIAL.printf("[HTTP] GET... failed, error: %s\n", http.errorToString(httpCode).c_str());
http.end();
delay(10000);
