ESP8266 AP mode won't let reconnect
Posted: Sat Jul 08, 2017 1:52 pm
Hi guys,
I have a problem with androids phones: after one connection they wont reconnect (forbidden acces). I use many of solutions as: another channel, make STA then AP, newer version of IDE 1.8.2 etc, same problem on various boards like nodeMCU, wemosD1, standalone ESP8266.
ESP boards version 2.3.0 in IDE.
This is my code:
This is my code:
#include <EEPROM.h>
#include <OneWire.h>
#include <DallasTemperature.h>
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
#define ONE_WIRE_BUS_1 4
#define ONE_WIRE_BUS_2 5
#define relej 13
OneWire oneWire_topli(ONE_WIRE_BUS_1);
OneWire oneWire_hladni(ONE_WIRE_BUS_2);
DallasTemperature sensor_topli(&oneWire_topli);
DallasTemperature sensor_hladni(&oneWire_hladni);
ESP8266WebServer server(80);
int dif_temp,gasenje;
bool prvo=false;
pinMode(relej,OUTPUT);
digitalWrite(relej,0);
EEPROM.begin(4);
dif_temp=EEPROM.read(0);
gasenje=EEPROM.read(1);
EEPROM.end();
sensor_topli.begin();
sensor_hladni.begin();
WiFi.mode(WIFI_AP);
WiFi.softAP("termostat", "12345678",10);
delay(2000);
server.on("/submit",handleSubmit);
server.on("/", handleRoot);
server.begin();
server.handleClient();
digitalWrite(relej,termostat());
void handleRoot() {
EEPROM.begin(4);
EEPROM.end();
char hladna[8];
char topla[8];
float f=daj_topli();
ftoa(topla, f, 1);
f=daj_hladni();
ftoa(hladna,f,1);
char temp[1090];
snprintf ( temp, 1089,
"<html>\
<head>\
<meta http-equiv='refresh' content='7'>\
<title>wifi termostat</title>\
<style>\
.button {\
background-color: #4CAF50;\
border: none;\
color: white;\
padding: 15px 32px;\
text-align: center;\
text-decoration: none;\
display: inline-block;\
font-size: 26px;\
margin: 4px 2px;\
cursor: pointer;\
} body { background-color: #cccccc; font-family: Arial, Helvetica, Sans-Serif; Color: #000088; font-size: 30px; }\
</style>\
</head>\
<body>\
<h1>Wifi termostat</h1>\
<p>Topla: %s C</p>\
<p>Hladna: %s C</p>\
<form action='http://192.168.4.1/submit' method='POST'>\
Diferencijalna temperatura(*0.5C):<input type='text' name='fname' value='%d' maxlength='1' size='3' ><br>\
Temperatura izjednacenja(*0.5C):<input type='text' name='temp' value='%d' maxlength='1' size='3'><br>\
<input type='submit' class='button' value='Podesi'>\
<a href='..' class='button'>Osvjezi</a>\
</form>\
</body>\
</html>",
topla,hladna,dif_temp,gasenje
server.send(200, "text/html", temp);
float daj_topli(void){
sensor_topli.requestTemperatures();
delay(100);
return sensor_topli.getTempCByIndex(0);
float daj_hladni(void){
sensor_hladni.requestTemperatures();
delay(100);
return sensor_hladni.getTempCByIndex(0);
void handleSubmit()
if (server.args() > 0 ) {
for ( uint8_t i = 0; i < server.args(); i++ ){
if (server.argName(i) == "fname") { uint8_t temp=server.arg(i).toInt();
EEPROM.begin(4);
EEPROM.write(0, temp);
EEPROM.commit();
if (server.argName(i) == "temp") { uint8_t temp=server.arg(i).toInt();
EEPROM.begin(4);
EEPROM.write(1, temp);
EEPROM.commit();
char temp[500];
snprintf ( temp, 500,
"<html>\
<body>\
<head>\
<title>WiFi termostat</title>\
<style>\
body { background-color: #cccccc; font-family: Arial, Helvetica, Sans-Serif; Color: #000088; }\
</style>\
</head>\
<body><br><br>\
<p>Postavke spremljene</p>\
<a href='..'><button>NAZAD</button></a>\
</body>\
</html>");
char *ftoa(char *a, double f, int precision)
long p[] = {0,10,100,1000,10000,100000,1000000,10000000,100000000};
char *ret = a;
long heiltal = (long)f;
itoa(heiltal, a, 10);
while (*a != '\0') a++;
*a++ = '.';
long desimal = abs((long)((f - heiltal) * p[precision]));
itoa(desimal, a, 10);
return ret;
bool termostat(void){
float g,dif;
dif=dif_temp*0.5;
g=gasenje*0.5;
float a=daj_topli();
float b=daj_hladni();
if (a-b>dif) {prvo=true; return true;}
if (a-b>g&&prvo==true) return true;
prvo=false;
return false;
