void loop()
// check if WLAN is connected
if (WiFi.status() != WL_CONNECTED)
WiFiStart();
if (!client)
return;
Serial.println("new client");
unsigned long ultimeout = millis() + 250;
while (!client.available() && (millis() < ultimeout) )
delay(1);
if (millis() > ultimeout)
Serial.println("client connection time-out!");
return;
String sRequest = client.readStringUntil('\r');
client.flush();
if (sRequest == "")
Serial.println("empty request! - stopping client");
client.stop();
return;
}The loop waits for an incoming message over wifi. But I want to do something more in the meantime, e.g. getting data from a sensor every minute. And I need an interrupt pin for a wind sensor (reed relais).
The problem seems to be the while loop:
delay(1);
How can I rewrite this section, that this is not blocking the main loop but also reading in the wifi-message and the sensor data?
