Unavailable network handling
Posted: Fri Aug 11, 2017 3:41 am
Dear All,
I am working on websocket powered webpage running on a NodeMCU. There is a main issue which bothers me. Whenever I connected to a network it works fine, if i disconnect from it and then re-connect it still okay. But if the network becomes unavailable and gone missing I can't connect to the ESP anymore.
Are there any ideas, how I can handle this situation? I attached my code
Also, I have another issue, which is when I connect to a network or reconnect to it or disconnect from it, I always need to refresh my webpage. Is it possible to refresh automaticly when it happens?
Thanks a lot
Thanks a lot
#include <WebSocketsServer.h>
#include <ESP8266WebServer.h>
#include <WiFiManager.h>
#include <DNSServer.h>
#include <Wire.h> //I2C library
#include <RtcDS3231.h> //RTC library
WebSocketsServer webSocket = WebSocketsServer(81);
ESP8266WebServer server(80);
WiFiManager wifiManager;
DNSServer dnsServer;
RtcDS3231<TwoWire> rtcObject(Wire);
IPAddress apIP(192, 168, 1, 1);
String serialText;
byte ledPin = D0;
byte secPin=D3; // second counter interrupt pin
byte sensorPin = A0; // IR sensor pin
int sensorValue=0;
int secCount=0;
int startTime;
int loopTime;
double moveTime;
const byte DNS_PORT = 53;
const char* ssidESP = "ESP";
const char* passwordESP = "szipusalfonz";
String webSite, javaScript, JSONtxt;
boolean LEDonoff = true;
int counter = 0;
char* ssidNET="ssidNET";
char* passwordNET="passwordNET";
String randszoveg="ESP homepage";
int ntpYear, ntpMonth, ntpDay, ntpHour, ntpMinute, ntpSecond;
int rtcYear, rtcMonth, rtcDay, rtcHour, rtcMinute, rtcSecond;
int clockEnabled=0;
void ICACHE_RAM_ATTR secondReceive() {
secCount=1;
void buildWebsite() {
buildJavascript();
webSite = "<!DOCTYPE HTML><HTML>\n";
webSite += "<META name='viewport' content='width=device-width, initial-scale=1'>\n";
webSite += javaScript;
webSite += "<BODY>\n";
webSite += "<BR><BR>Randomszoveg = <A ID='randszoveg'></A><BR><BR>\n";
webSite += "<BUTTON ID='button' ONCLICK='button()' STYLE='width:200px;height:150px'></BUTTON>";
webSite += "<BUTTON ID='wifiManager' ONCLICK='wifiManager()' STYLE='width:200px;height:150px'></BUTTON>";
webSite += "<BUTTON ID='discWifi' ONCLICK='discWifi()' STYLE='width:200px;height:150px'></BUTTON>";
webSite += "<INPUT ID='searchTxt' type='text' ONCHANGE='textbox()'/><BR><BR><BR>";
webSite += "<INPUT ID='networkName' type='text' placeholder='Input the network name' ONCHANGE='network()'/><BR>";
webSite += "<INPUT ID='networkPw' type='password' placeholder='Input the network password' ONCHANGE='pw()'/><BR><BR><BR>";
webSite += "</BODY>\n";
webSite += "</HTML>\n";
void buildJavascript() {
javaScript = "<SCRIPT>\n";
javaScript += "InitWebSocket();\n";
javaScript += "function InitWebSocket(){\n";
javaScript += " websock=new WebSocket('ws://'+window.location.hostname+':81/');\n";
javaScript += " websock.onmessage=function(evt){\n";
javaScript += " JSONobj=JSON.parse(evt.data);\n";
javaScript += " document.getElementById('randszoveg').innerHTML=JSONobj.randszoveg;\n";
javaScript += " document.getElementById('button').innerHTML=JSONobj.LEDonoff;\n";
javaScript += " document.getElementById('wifiManager').innerHTML=JSONobj.wifiManager;\n";
javaScript += " document.getElementById('discWifi').innerHTML=JSONobj.diskWifi;\n";
javaScript += " document.getElementById('searchTxt').innerHTML=JSONobj.searchTxt;\n";
javaScript += " document.getElementById('networkName').innerHTML=JSONobj.networkName;\n";
javaScript += " document.getElementById('networkPw').innerHTML=JSONobj.networkPw;\n";
javaScript += " }\n";
javaScript += "}\n";
javaScript += "function button(){\n";
javaScript += " btn='LEDonoff=LED = ON';\n";
javaScript += " if(document.getElementById('button').innerHTML==='LED = ON')btn='LEDonoff=LED = OFF';\n";
javaScript += " websock.send(btn);\n";
javaScript += "function wifiManager(){\n";
javaScript += " btnWifi='wifiManager';\n";
javaScript += " websock.send(btnWifi);\n";
javaScript += "function discWifi(){\n";
javaScript += " btndiscWifi='discWifi';\n";
javaScript += " websock.send(btndiscWifi);\n";
javaScript += "function textbox(){\n";
javaScript += " txt=document.getElementById('searchTxt').value;\n";
javaScript += " websock.send('searchTxt='+txt);\n";
javaScript += "function network(){\n";
javaScript += " name=document.getElementById('networkName').value;\n";
javaScript += " websock.send('networkName='+name);\n";
javaScript += "function pw(){\n";
javaScript += " pass=document.getElementById('networkPw').value;\n";
javaScript += " websock.send('networkPw='+pass);\n";
javaScript += "</SCRIPT>\n";
void handleWebsite() {
buildWebsite();
server.send(200, "text/html", webSite);
void webSocketEvent(uint8_t num, WStype_t type, uint8_t * payload, size_t lenght) {
String payloadString = (const char *)payload;
if (type == WStype_TEXT) {
byte separator = payloadString.indexOf('=');
String var = payloadString.substring(0, separator);
String val = payloadString.substring(separator + 1);
if (var == "LEDonoff") {
LEDonoff = false;
if (val == "LED = ON")LEDonoff = true;
digitalWrite(ledPin, HIGH);
digitalWrite(ledPin, LOW);
Serial.println("LEDSWITCH");
if (var == "discWifi") {
WiFi.disconnect();
WiFi.mode(WIFI_OFF);
WiFi.mode(WIFI_AP);
WiFi.softAPConfig(apIP, apIP, IPAddress(255, 255, 255, 0));
WiFi.softAP(ssidESP, passwordESP);
Serial.println(ssidESP);
Serial.print("Access Point IP address = ");
Serial.println(WiFi.softAPIP());
dnsServer.start(DNS_PORT, "*", apIP);
delay(1000);
if (var == "wifiManager") {
WiFi.disconnect();
WiFi.mode(WIFI_AP_STA);
int loopstartTime=millis();
int loopcurrentTime;
Serial.println("");
Serial.print("Connencting to network: ");
Serial.print(ssidNET);
WiFi.begin(ssidNET, passwordNET);
wifi_station_set_auto_connect(true);
while ((!(WiFi.status() == WL_CONNECTED))) {
loopcurrentTime=millis();
if((loopcurrentTime-loopstartTime)>15000)break;
if((WiFi.status() == WL_CONNECTED)){
Serial.println("Connected");
Serial.print("Station IP address = ");
Serial.println((WiFi.localIP()));
else{
Serial.println("Failed attempt to connect! :(");
WiFi.disconnect();
WiFi.mode(WIFI_AP);
configRTC(ntpYear, ntpMonth, ntpDay, ntpHour,ntpMinute, ntpSecond);
delay(1000);
if (var == "networkName") {
Serial.print("Typed network name: ");
val.toCharArray(ssidNET, val.length()+1);
Serial.println(ssidNET);
if (var == "networkPw") {
Serial.print("Typed password: ");
val.toCharArray(passwordNET, val.length()+1);
Serial.println(passwordNET);
Serial.begin(9600);
ESP.eraseConfig();
//Init pins
pinMode(sensorPin, INPUT);
pinMode(secPin, INPUT);
pinMode(ledPin, OUTPUT);
WiFi.mode(WIFI_AP);
Serial.println("");
// Init RTC second and voltage drop interrupts
rtcObject.Begin();
attachInterrupt(digitalPinToInterrupt(secPin), secondReceive, FALLING);
rtcObject.SetSquareWavePin(DS3231SquareWavePin_ModeClock);
rtcObject.SetSquareWavePinClockFrequency(DS3231SquareWaveClock_1Hz); //SQW set to 1Hz
configRTC(ntpYear, ntpMonth, ntpDay,ntpHour, ntpMinute, ntpSecond);
RtcDateTime currentTime = RtcDateTime(ntpYear, ntpMonth, ntpDay, ntpHour, ntpMinute, ntpSecond);
rtcObject.SetDateTime(currentTime);
// init website, dnsserver, websocket
handleWebsite();
server.on("/", handleWebsite);
server.on("/generate_204", handleWebsite);
server.on("/fwlink", handleWebsite);
server.begin();
server.onNotFound([]() {
webSocket.begin();
webSocket.onEvent(webSocketEvent);
dnsServer.processNextRequest();
server.handleClient();
webSocket.loop();
// communicating w/ webpage through JSON
JSONtxt = "{\"randszoveg\":\"" + serialText + "\"," +
"\"requestNTP\":\"" + "Get NTP data." +"<br /><br />"+"Current RT data: "+getRTC() + "\"," +
"\"wifiManager\":\"" +"Wifi Manager "+"<br /><br />"+ "\"}";;
webSocket.broadcastTXT(JSONtxt);
if(secCount==1 ){
startTime=millis();
getRtcTime();
sensorValue=analogRead(sensorPin);
/// everything else
loopTime=millis();
moveTime=(loopTime-startTime);
dataWrite();
secCount=0;
void configRTC (int year, int month, int day, int hour, int minute, int second){
rtcObject.Begin();
RtcDateTime currentTime = RtcDateTime(year, month, day, hour, minute, second); //define date and time object
rtcObject.SetDateTime(currentTime); //configure the RTC with object
Serial.println("Configured RTC");
String getRTC(){
RtcDateTime currentTime = rtcObject.GetDateTime();
rtcYear=currentTime.Year();
rtcMonth=currentTime.Month();
rtcDay=currentTime.Day();
rtcHour=currentTime.Hour();
rtcMinute=currentTime.Minute();
rtcSecond=currentTime.Second();
return String(rtcYear)+"/"+String(rtcMonth)+"/"+String(rtcDay)+" "+String(rtcHour)+":"+String(rtcMinute)+":"+String(rtcSecond);
void dataWrite(){
Serial.print("rtc Min:Sec: ");
Serial.print(rtcMinute);
Serial.print(":");
Serial.print(rtcSecond);
Serial.print(" SensorValue: ");
Serial.print(sensorValue);
Serial.print(" LoopTime: ");
Serial.println(moveTime);
serialText=" rtc Min:Sec: "+String(rtcMinute)+":"+String(rtcSecond)+" SensorValue: "+String(sensorValue)+" LoopTime: "+String(moveTime);
void getRtcTime(){
