By MrMU
#70110 Hi there,
For some reason I can't find out how to edit a sketch so the ESP01 that I use behaves like an access point.
I found a sketch that works fine when connected to my router.
But I want this ESP project to work for a long time, and don't want it to edit when something on my router changes.
My idea was to make the ESP an access point so it will work for a long time without interference..
I will cut a piece of the sketch, my only question is what do I have to edit to accomplish what I want.
Code: Select all#include <DHT.h>
#include <DHT_U.h>
#include "espipswitchtoggle.h"
const char* ssid = "MySSID";
const char* password = "MyPass";
// Create an instance of the server
// specify the port to listen on as an argument
WiFiServer server(80);
unsigned long timer = 0;
unsigned long firstMillis = 0;
  delay(10);
  pinMode(0, OUTPUT);
  pinMode(2,INPUT);
  pinMode(2, INPUT_PULLUP);
  // Connect to WiFi network
  Serial.println(ssid);
  WiFi.hostname("verw");
  WiFi.begin(ssid, password);
    Serial.print(".");
  Serial.println("");
  // Start the server
  server.begin();
  // Print the IP address
if(currentMillis - firstMillis > (timer*60000)) {
  digitalWrite(0, 0);
By MrMU
#70115
martinayotte wrote:Did you look at this example ?
https://github.com/esp8266/Arduino/blob ... sPoint.ino
Hey thank you,
But I'm more an hardware guy then a software guy.
The thing is that I tried so many things, but sometimes I corrupt the INO I'm working on with my changes.
The only thing I need to change is that the ESP acts like a access point.
And that's the thing, I always change things and then the INO doesn't compile or the ESP doesn't work anymore..
So what do I change if I can ask this on this forum?
By martinayotte
#70116 The example above is pretty straight forward.
Instead of doing WiFi.begin() and WiFi.status(), simply do the following as in the example :
Code: Select allWiFi.softAP(ssid, password);
Serial.print("AP IP address: ");
Serial.println(myIP);
