Change sketch to access point
Posted: Tue Sep 19, 2017 11:35 am
Hi there,
For some reason I can't find out how to edit a sketch so the ESP01 that I use behaves like an access point.
I found a sketch that works fine when connected to my router.
But I want this ESP project to work for a long time, and don't want it to edit when something on my router changes.
My idea was to make the ESP an access point so it will work for a long time without interference..
I will cut a piece of the sketch, my only question is what do I have to edit to accomplish what I want.
#include <DHT.h>
#include <DHT_U.h>
#include "espipswitchtoggle.h"
const char* ssid = "MySSID";
const char* password = "MyPass";
// Create an instance of the server
// specify the port to listen on as an argument
WiFiServer server(80);
unsigned long timer = 0;
unsigned long firstMillis = 0;
delay(10);
pinMode(0, OUTPUT);
pinMode(2,INPUT);
pinMode(2, INPUT_PULLUP);
// Connect to WiFi network
Serial.println(ssid);
WiFi.hostname("verw");
WiFi.begin(ssid, password);
Serial.println("");
// Start the server
server.begin();
// Print the IP address
unsigned long currentMillis = millis();
if(currentMillis - firstMillis > (timer*60000)) {
digitalWrite(0, 0);
